LQ4 ring gap
Old Apr 7, 2020 | 08:36 AM
RySmDPT14's Avatar
Default LQ4 ring gap
Putting an lq4 together. The original 250k rings were .038”. New pistons rods and rings from WS6 store are going in. Right now rings are .023” for top. What ring gaps have you all seen works well with 10-15 psi boost? I’ve reading and have .024-.028 and varying opinions on bottom ring being same or larger.
Old Apr 7, 2020 | 09:15 AM
RB04Av's Avatar
5 Year Member
Usual rule of thumb for top rings is around .0045 - .005 per " of bore N/A; add acoupla .001"s for boost. So .025 - .028 is pretty much right in there.
Bottom compression ring should be a little larger. Not much, but a little. Maybe 10 - 15%.
The penalty for slightly too much ring gap (emphasis on SLIGHTLY) is slightly more blowby. The penalty for too little ring gap, even a TINY amount too little, is instant catastrophic total destruction when the ends butt up against each other at max boost, max power, and max RPM, when they grow to their max size due to heat.
Which penalty would you rather pay? Make your decision accordingly.
Old Apr 7, 2020 | 05:32 PM
RySmDPT14's Avatar
WS6 got back to me and states .026 top and .024 bottom... always though they would be the same or bottom would be larger... no?
Old Apr 7, 2020 | 05:57 PM
RB04Av's Avatar
5 Year Member
The .026" top is extremely believable.
Most people set the bottom larger these days; lets the pressure out from between them. If it was me I might go .026 & .030".
Butt hay, it's not THAT much difference anyway, and if they say what they say, they've done more of this than me, and if they offer a warranty on it, ...
Old Apr 7, 2020 | 10:39 PM
1FastBrick's Avatar
Custm2500's Rude Friend
There is plenty out there on the subject. You might find these articles helpful.
https://www.enginelabs.com/engine-te...-ring-end-gap/
Everything You Need to Know About Ring Gap!
Old Apr 8, 2020 | 03:52 AM
RySmDPT14's Avatar
Read those and everything else you can find on the first three pages of google.... no diff omit everything Answers, wheat I did determine is 26/28 are the most common gaps people run and seem to do well. Right now mine are 23/23 so not too far off.
Sierraman02
Jun 19, 2018 07:21 PM
dirt track racer 81
Feb 3, 2008 09:43 PM
FirstGen
Jul 1, 2004 10:16 PM
