LQ4 Cam Choice Help??
Old Dec 29, 2011 | 03:23 AM
rfugio68.'s Avatar
Is a higher stall converter really that much better? Im on the same boat as the OP and am getting a circle D 3200 due to price.
Old Dec 29, 2011 | 11:03 PM
La_BigShit0389's Avatar
Go for a 228r or torquer v2cam
Old Dec 30, 2011 | 05:32 PM
Beatdown Z's Avatar
Laid Back
Yea, it's a pretty big difference.
Old Dec 30, 2011 | 06:31 PM
jrmchevyman's Avatar
The circleD 278mm is a nice budget friendly converter, but depending on your setup, goals, etc it will be a little tame like stated already. Especially if you go for a TSP228R or bigger cam the 278mm will be pretty tame.
A few other companies out there offer some good deals on converters a notch above the 278mm, but costs a little more money. A 10.5" or a 10" higher stalling torque converter which is a smaller diameter converter vs the 278mm can be had for around $500-$600.
FTI, Midwest, Edge racing converters has some pretty good deals, but you need to contact them. FTI could probably custom build you a 10.5" 3400-3600 converter non billet for not much more than the 278mm.
Old Jan 5, 2012 | 09:01 PM
WhiteChevy3's Avatar
Thanks for the comments guys, i will report back with my results when the swap is done. As mentioned i will probally end up save a few more $ and get a bigger stall.
GrooveCityZ71
Aug 31, 2015 12:05 PM
darnie
Aug 10, 2015 10:25 AM
JordanH
Aug 8, 2015 07:59 PM
jaypowe11520
Jul 29, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
