Looking for good daily cam
Old Aug 15, 2021 | 07:07 PM
Dmeddly's Avatar
Registered User
Default Looking for good daily cam
So I have an 05 base model ext 4.8 Silverado, and I知 looking at cams. But I want a cam that痴 good for daily driving but also gives the truck good power gain. I知 looking at a TSP cam that says (new to this still) duration .050, intake 222 exhaust 222, lobe lift .353/.353, valve lift @1.7 .600/.600, lobe separation 112, intake center line 108, is this a good daily? If not what are good choices for what I知 looking for
Old Aug 15, 2021 | 07:50 PM
vettelovralexand's Avatar
4.8L in an extended cab truck, you are looking too big. I assume from your specs that you're open to a spring and some form of rocker trunion upgrade?
Either way, on a 4.8 you will probably be best off with something sub 210 intake duration like most stage 1 cams. Otherwise you'll be shifting your powerband above normal truck operating speeds. Texas speed sells a stage 1 low lift truck cam that would be fine but so do several companies.
Old Aug 15, 2021 | 09:48 PM
68Formula's Avatar
What compression ratio? What rear gear and tire? Torque convertor stall?
Old Aug 15, 2021 | 10:01 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Stock 4.8 is 9 CR. I'm assuming he has 3.23s and stock stall lol
No offence OP but those are the vibes your post gives off
Old Aug 17, 2021 | 10:44 AM
Summitracing's Avatar
LS1Tech Sponsor
We agree with others. This seems to be swinging for too much. Something we'd look at for a truck with a stock 4.8 would be our Pro LS Truck stage 1 high-lift cam. That's part number SUM-8719R1. Specs on it are .550/.550, 209/217, 112+1 with -10* of overlap. Pair that with some budget-friendly LS6 springs and it'll be happy to 6,500+. That will work just fine with stock gearing and converter.
This is also available in a combo with items to help with the cam swap. That would be part number SUM-8719-2-BHV. This gets you the cam, springs, valve seals, harmonic balancer bolt, and a cam change gasket set.
Old Sep 1, 2021 | 09:05 PM
tnbubba's Avatar
or smaller cam with 525 lift the 4.8 dotn responed to cams as well as larger motors..
get a blower! now those things work
Old Sep 15, 2021 | 09:18 AM
Runnerxs's Avatar
Banned
BTR GEN III & IV TRUCK CAM - TORQUE - 30202111R1
Pretty sure you don't have to change springs or pushrods. I would also get speed engineering long tube headers and y pipe. This would add power from idle to 6000.
07NBSChevy
14
Nov 29, 2016 09:20 AM
apexss
Nov 14, 2011 10:25 AM
chevyz7120
Nov 26, 2009 09:23 AM
moregrip
Nov 8, 2004 12:10 AM
Yellowsierra
May 31, 2004 07:01 PM
