Looking for the best cam for a stock 5.3
Old Dec 8, 2022 | 01:56 PM
strutaeng's Avatar
5 Year Member
I was going to suggest a muffler, but I thought I was going to sound like a novice. ☺️
My Suburban had some Flowmasters from the previous owner I bought it from. They were loud!
I don't like loud mufflers, so I wound up finding another OEM muffler at a part-out place and getting that swapped back. My wife actually made a comment once that she could hear me one block after leaving the house! 🤭
Old Dec 8, 2022 | 07:02 PM
terravast4's Avatar
If you want lope for $200. Remove two spark plug wires. Keep the $200
Old Dec 8, 2022 | 07:58 PM
68Formula's Avatar
Originally Posted by Modern Barbarian
Sloppy stage 2 kit.
https://www.amazon.com/LABLT-Sloppy-...4-dc28e6d374b3
not this exact kit, but I run this cam in my truck and like it. plenty of lope at idle.
Wow a knockoff with spings and pushrods, no ratings, and sold by a company vendor that specializes in lighting; for only $35 more than just the real cam itself. Surprised they don't throw in the needed higher stall convertor for an extra $10.
Old Dec 8, 2022 | 11:08 PM
RDF1's Avatar
DuNnO
5 Year Member
I'd suggest replacing all of those parts while in there, but I've also successfully re-used all of those gaskets/plates successfully...I wouldn't say that they are required. Just best practice. Dont forget springs.
Ive reused some when its a rush job but i cant afford to have a comeback so i use new gaskets.
Old Dec 8, 2022 | 11:20 PM
RDF1's Avatar
DuNnO
5 Year Member
Originally Posted by shakenfake
Someone walked me through tuning my girl's dad's Suburban like that. Personally I think the tune was dogass but this guy swears he knows what he is doing, I had no real say in the matter. @RDF1 You tune for a living right? I also don't get how that doesn't make the engine run less and less efficiently at idle lmao so bad
Bascially your just adjusting the Timing at idle to overcorrect and induce a idle that is unstable.
This is from a 2003 Silverado tune i read off earlier today. Imagine you have 16-18* timing at idle. Then throw in 20* and subtract 20* over and over and over..
Ive seen some tunes that were swinging +/- 35* at idle. Someone kinda local is making a killing on these kids tuning them like that. Raise top speed limiter, raise rev limiter, and that stock cam TOONER Idle Chop Chop..
Worse part is the guy has been locking the PCMs.
Old Dec 8, 2022 | 11:26 PM
RDF1's Avatar
DuNnO
5 Year Member
Sloppy stage 2 kit.
Great way to ruin a engine.. Ive got quite a few engines in the shop with Chinese cam shafts and lifters. They don't last long and it would have been cheaper to go with a known supplier cam than having to rebuild the engine cause the metal glitter soup in the pan doesn't lubricate well.
Old Dec 9, 2022 | 06:19 AM
68Formula's Avatar
And he locks them too?! What a jackwagon!
Old Dec 13, 2022 | 07:44 AM
Modern Barbarian's Avatar
I guess you guys missed where I said not the exact kit, just showing specs. The sloppy stage 2 cam is not expensive and is known to work well. Here is the link to the Elgin cam that I actually used,
https://www.amazon.com/gp/product/B00EZ7DTZ2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00EZ7DTZ2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
That said, this cam will need springs and a vvt delete, which will add cost. You won't get out of this for 200 bucks, but you can get the cam for that price and then buy the other parts you need as you get funds. A new muffler won't make it sound like it has a cam, the "cam tunes" are dumb and do nothing for you. If you want a cam, get a cam and keep putting parts on the shelf until you have everything you need. Then you can install it all at once and actually have what you want.
Old Dec 13, 2022 | 10:26 AM
RDF1's Avatar
DuNnO
5 Year Member
He has a 02 so no VVT stuff.
The SS2 cam on a stock converter is terrible.
Old Dec 13, 2022 | 10:42 AM
Well he could do like me and and a blower at the same time, then the torque is good enough to overcome the converter.
I really do need a converter though.
5.3juan
Jan 23, 2018 08:55 AM
srt8superbee
11
Jan 14, 2010 09:20 PM
silverado 5.3
Apr 24, 2008 10:59 PM
nlcrewcab
Aug 27, 2007 07:05 AM
highgmc
May 18, 2003 06:21 PM
