Lifters, help
Old Feb 24, 2017 | 12:29 PM
Furdkiller's Avatar
Default Lifters, help
I'm having trouble choosing a set of lifters for my engine. I'm going to be shifting around 7,000-7,500 rpm, I want to stay away from the ls7 lifters. Any help is appreciated thank you.
Old Feb 24, 2017 | 02:01 PM
03sierraslt's Avatar
What type of spring pressure will you be running? Make sure you run a good pushrod also.
Old Feb 24, 2017 | 03:45 PM
Ken in AZ's Avatar
Comp short travels are decent and there are a few other short travel lifters out there that are for higher rpm use and still retain the ease of preload adjustment. On my Comps they call for 1/4 turn but I went a half turn because they were noisey at 1/4. Not sure what that relates to as far as preload .0XX" Best bet would be to go full solid but then you have to set lash and continually maintenance.
Old Feb 24, 2017 | 06:44 PM
91LT16SpeedFormula's Avatar
Whats wrong with the LS7 lifters? Just wondering.
Old Feb 24, 2017 | 08:01 PM
arthursc2's Avatar
Quality issues as of late, and hard to determine if you are getting genuine ACDelco, or knock off crap.
Old Feb 24, 2017 | 08:05 PM
Great, I just stopped by Summit and got a set couple of weeks ago
Old Feb 24, 2017 | 08:24 PM
arthursc2's Avatar
Did they come in ACDelco boxes?
Old Feb 24, 2017 | 08:26 PM
I have Johnson link bars in my new motor. Quality lifter IMO.
Old Feb 24, 2017 | 08:32 PM
Yes in Delco box
Are Johnson lifters better then the GM LS7s?
Old Feb 24, 2017 | 09:01 PM
Originally Posted by 91LT16SpeedFormula
Yes in Delco box
What?? In a Delco box, no.
I wouldn't run an LS7 if you gave them to me. All I can tell you is do your own research and decide for yourself.
