Which lifter for my cam upgrade???
Old Jun 13, 2014 | 04:08 PM
Kalehuawehe2646's Avatar
Default Which lifter for my cam upgrade???
So I've heard many different things about the compcam 875-16 lifter and need to know if it will work cause I'm about to pull the trigger on my cam upgrade...
I have a 2011 Tahoe with the 325 5.3L... I am going with the 156-456-11 camshaft 219/235 .607/.621 113lsa, 7955-16 pushrods, 26926TS-KIT spring kit... So there are two options for this set up for the lifters: 850-16 and 875-16. What do you all think??? Thanks in advance!!!
Old Jun 13, 2014 | 04:12 PM
Richardman1992's Avatar
What are you going to be doing with your Tahoe that requires such a big cam?
Old Jun 13, 2014 | 05:02 PM
black00chev's Avatar
Slowest turbo build ever!
Get the Brian Tooley SLR lifters.
Old Jun 13, 2014 | 06:15 PM
Vortec350ss's Avatar
he discontinued them. Wasnt impressed by their performance. I talked to Brian about it a couple months ago right before he made the decision...
Old Jun 13, 2014 | 06:17 PM
GMCtrk's Avatar
Unless you step up to the .750 wheel morel lifters, there's nothing under $500 that's worth using instead of ls7 lifters IMO.
Old Jun 13, 2014 | 06:55 PM
Is it??? Compcam peeps said that it would be good for my heavy Tahoe since the power kicks in low on the power band...
Old Jun 13, 2014 | 09:20 PM
gamble686's Avatar
Link bars or stock lifters. Also that seems like way too much exhaust duration unless you have plans for 300 shot or a supercharger.
Old Jun 14, 2014 | 04:59 PM
Txblue's Avatar
I agree on cam size being too big. It would be ok if you want to run a 3000 stall converter. No cam will make more low end power than the stock cam but you can retain that power until a point. That cam would probably do alright on a stock converter in a single cab but I think you would be happier with a 212/218, ht-1 cam, or the trickflow 216/220. Just my .02
Old Jun 17, 2014 | 02:55 PM
I am definitely getting a stall!!! Also port and polishing my heads... I already have headers, intake, exhaust... So this cam should be fine with these mods???
Old Jun 17, 2014 | 03:50 PM
Z71crawford's Avatar
Who spec'd your cam?
