Lets talk LM4/L33, time for a build..
Old Mar 8, 2013 | 05:58 AM
  #21
pewterliftedz's Avatar
With the amount of boost you want to run, Rob, I'd keep as much cylinder wall as possible.
Old Mar 8, 2013 | 06:57 AM
  #22
Byrdman11's Avatar
Biggest bore u can get, help head flow. Crank? I wouldnt use 4.00 because of its harder on the block.
Old Mar 8, 2013 | 09:04 AM
  #23
foose04's Avatar
The more posts I read about the erl super decks it seems like a standard aluminum block would have some issues at my power level. I think it would live forever with 6-700, but I think really working it could lead to issues down the road from cylinder flex and main bearing wear. This seems to be what ERL addressed with tresses and a girdle. The girdle is 500 bucks so at that I should have just went iron block.
I'm currently leaning toward a iron block and selling this one.
Old Mar 8, 2013 | 09:12 AM
  #24
smokeshow's Avatar
Mod with training wheels
Remember to account for marketing bias in your decision... Either way I'd speak with Jarrett (stock48) about it. He's been digging through aluminum block stuff for a while now for all his neat little projects
Old Mar 8, 2013 | 09:23 AM
  #25
skeet's Avatar
ERL is good, if he said it i believe it, ive talked to 3 builders, i was wanting to build a big bore NA solid roller for next year. after i have fun with the 408 or at lease accomplish what im out to set with it as my goal of just a 10 sec NA pass with a hydraulic roller . anyway i want to spray the same amount ( 400 ) on a aluminum block they told me i wouldnt beable to spray over 200-250 regardless if the tune was spot on or not. stock48 is right look for the block he mentioned, but also remember its just like your 4.8 youll still be on the edge even with a 5.3 and worse with an aluminum block.
dont put yourself in the situation of maybe having to do it twice, build the short block to your liking and have fun with it.
Old Mar 8, 2013 | 09:26 AM
  #26
RoadKill03's Avatar
I would go iron and I got dibs on the aluminum block if you want to sell it. This is what I would build, 6.0 block 4.000 bore with your 4.8 crank 3.27 stroke. This will make a big bore short stroke 5.3 ;-)
Old Mar 8, 2013 | 09:50 AM
  #27
Camin00's Avatar
I have seen your red truck on youtube. Very sweet truck man jealous haha
I'm no expert on boost except what I learn from yall on the form. I like your idea of weight reduction. Would lowering compression to 9.1 help relieve stress on the block with your boost levels?
Old Mar 8, 2013 | 10:11 AM
  #28
foose04's Avatar
With what rods and pistons? Still haven't found or had any one post part numbers for a set of rods and pistons that will work with a 4.8 crank.
Old Mar 8, 2013 | 10:17 AM
  #29
RoadKill03's Avatar
I'm sure I can make that happen for you if you are interested on doing that.
Old Mar 8, 2013 | 11:16 AM
  #30
Jake99's Avatar
Any reason you don't just buy a 6.0 and putting forged rods and pistons in it? Throw you cam and studs in it and go? My brother has a 6.0, vs my 4.8 its a beast! He's got a 216 220 cam and it rips Damm hard to 6500 were he shifts it, I think your turbo would flow it just fine.
