Large main bearing housing bore?
9 Second Truck Club
Anyone found the main bearing housing bore .0015'' over the high spec on a factory iron 6.0L? Looks like GM is trying to **** with people on this, the factory bearings are larger OD than the new FM comp series bearings I have hear.
9 Second Truck Club
After the line hone(studs) we set the housing bore right in the middle of spec. Clearance is right at .0007''~.001'' with the GM bearings. With the FM's I get .002~.0022" I would like to be right at .0025''~.00275".
I hope you are using a good pump with those tolerances. Rick
9 Second Truck Club
Thanks for sharing your thoughts, I agree that over .0025'' would be getting loose. After checking out my old engine I have decided to set this one up the same. It was running right at .002'' with 5w~20 oil, and bearings still look perfect even after the blow up. I just have a stock 6.0L oil pump like the old engine. I have 3 sets of main bearings orderd so hopefully one will come in where I want. As for the cam bearings we will see shortly what kind of night mare Im getting into with those. Seems like every Gen 3 I have looked at new or old had copper showing on the cam bearings. I did a cam in a 6.0 that only had 2500 miles and had copper showing.
R
9 Second Truck Club
Like he said earlier the factory installs the bearings, and line hones the cam tunnel with the bearings in. That's why you can have a new engine with copper showing on various spots the cam bearings. If you have a block with weird cam journals, and don't duplicate that possess you could be in trouble. The more copper, showing the more chance the cam tunnel is off. I have new bearings Im going to instal, and check, but if anything funny is going on the factory bearings are going back in.
