l92 power handling
Old Feb 13, 2011 | 02:22 PM
viciousknid's Avatar
Where's the Beef?
Default l92 power handling
since the L92's have a weaker deck I was wondering what kind of power some of you are making with them? I'm considering going with Milled L92's 030 with a -16 Piston on my 408 which should be around 10.1 CR N/A and then if I go F/I later I'd put non milled back on which should drop me back down to 9.6.
If they can't handle a whole lot of power I may need to move to an LS9 head after the fact and they cost a bit more. Want to figure this out before I order my rotating assembly because I need to make sure I have a Valve Relief that is just right to do what I wana do.
Old Feb 13, 2011 | 02:55 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
There is a TT TBSS making well over 1000 to the ground with them...
Old Feb 13, 2011 | 02:56 PM
Where's the Beef?
good to know. Do you know if he machined the block for bigger head bolts?
Old Feb 13, 2011 | 03:00 PM
1slow01Z71's Avatar
He is running the L92 block also but Im not sure on the head studs. He posts as DBTBSS on here or purpleminivan on ls1truck
Old Feb 13, 2011 | 03:12 PM
Where's the Beef?
hmm.. Looks like he hasn't been online in a few months. I'll see if I can find out if the L92 block has different bolts but I doubt it.
OHsixLS3
Dec 27, 2016 09:30 AM
Corvette454l88
Sep 1, 2016 01:24 AM
DwDrummer
Jul 24, 2015 07:05 AM
