L92 head milling
Old Mar 9, 2008 | 03:39 PM
Canucktrux's Avatar
Default L92 head milling
After searching all day, i'm still unsure of a few things regarding a potential L92 head swap onto a LQ9.
My only issue is the loss of compression, and wonder if milling is an option to get back to optimal compression, around 11:1 ish, with a stock bore, flat top.
How much milling, gasket thinkness would be required for this..sorry if this has been asked before, i just couldnt find the info myself.
TY
Old Mar 11, 2008 | 07:43 PM
OnyxSilveradoSS's Avatar
from my research unmilled will bump the compression a very slight bit and you can use 7.4 push rods.
and I am going to use the MLS GM head gaskets.
Old Mar 11, 2008 | 08:05 PM
TurboGibbs's Avatar
317's are 70-71cc and L92's are 69-70cc. essentially the same. LQ9's have 10.5:1 stock.
Old Mar 11, 2008 | 08:25 PM
06sierra5.3's Avatar
i will be running an lq4 with l92's milled to get about 10.4
talk to richard at WCCH, that is where i am getting mine from.
Old Mar 11, 2008 | 08:49 PM
Canucktrux's Avatar
Found this old thread on tech with some interesting info about L92 swaps
https://ls1tech.com/forums/showthrea...hlight=slp+l92
Old Mar 11, 2008 | 09:48 PM
We also use the correct/different spring seats and new valve seals to make 1.800 install height. Using the stock L92 spring seats with valve seals (one piece) will give a compressed install height (unless you mill down the head under each spring seat). We are not just slapping springs and retainers on these heads, that does not work.
is this true? Cant I just throw on these 918's I have??
Old Mar 11, 2008 | 10:02 PM
i dont know why he would say it if it wasnt true, unless he missed something. maybe have to have new spring seats installed.
look for C6R Motorsports on Ebay, they offer a package as well for around the same price.
Old Mar 11, 2008 | 10:21 PM
spent the last 1/2 hour reading and it might help if they come in a little shy, 1.78. and even gm springs dont exactly measure that much. I just need to check them when they go together.
I get lost reading on tech
USMCvet0311
Sep 30, 2015 10:34 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
lxcoupe
Aug 26, 2015 07:24 PM
subeone
Aug 19, 2015 07:44 AM
BennyB
Aug 1, 2015 08:48 AM
