L33 block deck height
Old Jul 20, 2010 | 10:22 PM
swift700's Avatar
Default L33 block deck height
Does anybody know the actual block deck height of the aluminum L33? Has anyone ever had theirs measured? Also, what is the maximum safe bore size for these blocks?
Old Jul 20, 2010 | 10:28 PM
Atomic's Avatar
I have a gauge for that
I think its 9.240....
Old Jul 20, 2010 | 10:45 PM
swift700's Avatar
I think you meant 9.240. At any rate, I've seen measurements for some 5.3 blocks as being 9.230. I'd like to make sure before I order pistons.
Also, does anyone know what the differences are in the l33 block (gen III) versus the LH6 block (gen IV)? I've read that some sensors were relocated... anyone know which ones? Are there any other differences?
Old Jul 20, 2010 | 11:19 PM
Atomic's Avatar
Oopps, yea, typo there
Old Jul 20, 2010 | 11:35 PM
pewterliftedz's Avatar
if im not mistaken it is the knock and cam sensors that got relocated
Old Jul 21, 2010 | 10:48 AM
Sales2@Texas-speed's Avatar
Former Vendor
Correct, the cam and knock sensors moved between the Gen3 and Gen4 engines. Most all of the iron blocks that come through here are 9.235-9.240"....however the finish work we see on bare blocks straight from GM has declined over the past few years, so we deck EVERY block that comes through to ensure the deck is flat and at a lower RA. I'd go ahead and plan to deck it to 9.230 or 9.235"" and build accordingly with the confidence in knowing that you'll have a great head gasket seal and pistons that are exactly x.xxx" above or below the deck for calculations purposes.
Old Jul 21, 2010 | 09:02 PM
swift700's Avatar
Awesome guys! I looked at the block today and found these #'s:
5.3l
P44894
330202075
Does anyone know if this would be a gen III or IV? Those were the only #'s I saw.
calsdad
Jun 14, 2023 11:07 PM
gmcyukon
Oct 5, 2015 06:20 AM
Mark_k
Oct 1, 2015 11:17 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
