L33 5.3 Cam???
Old Jul 2, 2008 | 01:31 PM
WJ MARK's Avatar
he was thinking of a ls6 cam but wants somthing alittle more aggressive
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by InchUp
Yes, he's losing power and throttle response where he needs it all below 6500 rpms. I grow weary of trying to get this point across to forum members so I'm not even going to bother this time. I've covered this material before, if you're interested, search for it because I'm not wasting my time anymore.
Ever see my truck in action?
You have got to be kidding me with that statement. Do you even know how a camshaft works?
Probably the most intelligent thing you've said all night.
I've been around the block a time or two
Im not going to get into a pissing match with you but you are welcome to search some of my old motor build threads, and ask anyone on here how much work I've done for people.
WJ I can't view that link from my phone but Ill check it when I get home. For what you are talking about I believe a 224 duration cam will be perfect if he is really intending onwringing it out. That 224 cam will really come alive at 3500 rpms and up. I had a 222/224 on a 112 in my old z71 when I had a stock 5.3 and it really ran good in the higher rpms, it added a good 40-50hp up top.
Cody
Old Jul 3, 2008 | 12:18 PM
WJ MARK's Avatar
thanks for the input guys. I'll let him Know.
Old Jul 6, 2008 | 09:53 PM
zippy's Avatar
The cam I'm running is a 222/224 on a 112. I'm more than happy with my torque below 3000rpm. I can pull up a hill with the converter locked in while in overdrive at 1500rpm. I've also sold and tuned for this cam in a friends L33 powered Silverado. With only a TB converter he had all the torque he needed to light the tires from a standstill off idle. He also off roads the truck including alot of sand hill running. With the truck weighing in at well over 5,000lbs (sometimes over 6k with friends in the truck) he could still stop in the middle of the hill and have enough torque to get it right back to 6k rpm and higher. He later went with more tire, 4.56 gear, and 3000 stall. Now he has a Radix. LOL.
JordanH
Aug 8, 2015 07:59 PM
jaypowe11520
Jul 29, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
