Just forged pistons?
Old Sep 6, 2007 | 07:24 AM
Raffman's Avatar
Default Just forged pistons?
Looks like I'm going to have to rebuild the bottom end of the 6.0 due to water laying in the cylinders when it was stored. I want forged pistons because of the Procharger but forged crank & rods is getting over-budget. Would just pistons be OK, who has the best price? Going for cnc head work and bigger cam so HP is 600 or so.
Old Sep 6, 2007 | 09:47 AM
Richard@WCCH's Avatar
FormerVendor
I think Diamond Pistons and Mahle are the only companies that sell forged replacement pistons that can be used on the stock rods. If you're going to try to reuse the stock rods, you'll want to replace the rod bolts with a better bolt. You might also try to find a set of LQ9 rods as they're a stronger rod than the LQ4.
Good luck,
Richard
Old Sep 6, 2007 | 09:51 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
LS2 rods are also a good option, they are the same as LQ9 rods.
Old Sep 6, 2007 | 10:15 AM
jasond26's Avatar
This is not the place really but I have some diamond pistons with eagle h beam rods assembled and balanced for sale. They will give you a 9.0/1 compresion ratio with a 72cc head and they have about 8000 miles on them. You would need to bore your block .030 over though.
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
