I need help asap
Old Dec 11, 2008 | 01:14 AM
piratekeith's Avatar
Registered User
Default I need help asap
i know this is the wrong forum but i cant find help anywhere...
i have a 99 tahoe with a vortec 350..one of the piston rods broke off and instead of taking the time to rebuild it since its my only vehicle i bought an engine off a buddy of mine..
its a 350 out of a 78 k10
now i heard all i have to do is swtich the heads over and im fine..but at the same time the 78 engine block didnt have a know sensor or crankshaft sensor since they werent computer controlled...is this going to work..using the 78 block with my 99 vortec heads...please i need to know now before we finish this project this weekend
Old Dec 11, 2008 | 08:10 AM
fastgmc53's Avatar
14 Second Truck Club
no. the 78 block will not work in your vehicle if you plan on using the fuel injection system. The computer uses the crank sensor for timing and advance and you can use vortec heads and intake on older blocks but can't use older blocks with the stock fuel injection.
Old Dec 11, 2008 | 12:08 PM
Truckshop's Avatar
The crank sensor is in the timing cover and the reluctor wheel goes on the front of the crank after the timing chain. You can make it work but you will need a few extra parts.
Old Dec 11, 2008 | 12:10 PM
hog's Avatar
hog
You will need to use the Vortec front timing cover(which holds the crank sensor),crank reluctor.
Also the Vortec balancer is thinner to help fit the reluctor under the timing cover. Either use the Vortec balancer or throw the older balancer into the lathe and end face it slightly to accomodat the relcutor.
The Vortec timing cover will work on the older block, even though its got a different number of boltholes. the holes that are there do match.
Knock sensor can be mounted elsewhere on the block.
peace
Hog
Old Dec 11, 2008 | 07:42 PM
Registered User
are you guys sure that this will work and that the sensors will all bolt up???
where could i possibly put the knock sensor at??
Old Dec 11, 2008 | 07:52 PM
Mangled03gmc's Avatar
Baltimore Whore
I am pretty sure what HOG said is correct...
John
Old Dec 11, 2008 | 08:14 PM
Registered User
also how do i set up the distributor as far as the gear and everything i want to do it right...so i dont have to send it into chevy to have the adjust it..
Old Dec 11, 2008 | 08:29 PM
dirt track racer 81's Avatar
also somethin else you need to think about the 78 is internally balanced whereas the 99 is externally balanced, unless the 97-99 were changed to internally balanced
Old Dec 12, 2008 | 10:45 AM
Registered User
hmmm i hope that it will all bolt up
Old Dec 12, 2008 | 08:24 PM
hog's Avatar
hog
You will need a different flexplate as the 97-2002 305's and 350's are 1 piece rear main seals so they use different flexplates and starters.
The 87+ flexplate will have a counterweight, the older 1's wont, both use a neutral balancer.
If you take the entire 78 350 and flexplate I think you'll need a different starter than the Vortec 350 starter.
peace
Hog
