I know sry, is 636 lift doable in lq4
Old Oct 29, 2006 | 10:17 PM
  #21
Sport Side's Avatar
Originally Posted by joshluther
Your right I meant to say duration effects it more than lift. But I definitely would not put that cam in with milled heads with out checking PTV clearance.
You don't want to be one of the guys on the net blowing up a motor.
Actually, you were correct with your first comment. Given so much clearance due to piston height, dome/dish, reliefs, head milling, valve angle, and valve size leaves one other major factor - The valve events.
Think about where the piston is when the valve is reaching max lift. The intake valve hits peak lift when the piston is headed down the bore. The exhaust valve reaches max lift while the piston is coming up, but it is way down in the bore................... so, what does that leave us with? When the valves are opening and shutting... Valve events...... Duration, LSA, ICL
Old Oct 29, 2006 | 10:27 PM
  #22
onebadrubi's Avatar
English please?? LOL j/k just have to read 2-3 times.
Old Oct 29, 2006 | 11:36 PM
  #23
Sport Side's Avatar
Let me see if I can explain it like this.
We'll only look at the intake valve relative to the piston.
cam: 220* of duration @ .050'', 112 LSA, 0* of advance
VE's: -2* ATDC, 42* ABDC
VE's: IVO/IVC - Intake Valve opens, closes
With 220* of duration and a 112* LSA, with 0* of advance the intake valve will open 2* after the piston has reached top dead center (TDC) and the intake valve will close 42* after the piston has reached bottom dead center.
The piston came up, pushed all of the exhaust out and 2* after it started heading back down the intake valve opened. The piston went all the way back down and 42* after it reached the bottom, it closed.(the beginning of dynamic compression.... )
Time out. Read it again. All of it.
Okay. What do we have? The valve opened 2* after the piston reached the top. The piston then went all the way down and became coming back up. All of this time by the way, you are bringing in the intake charge. 42* after the piston reaches the bottom, the valve closes.
This means that somewhere inbetween all of this, peak lift was met. It happened at the very middle if it's a symetrical lobe (equal up the lobe and down). The valve has opened near the top and closed after the piston started coming up. The middle of all that is somewhere while the piston has started traveling down the bore.... Pretty far down the bore I might add.
If this cam has .550'' of lift or 600'' of lift, it's probably not going to matter because the piston is so far down the bore. What is going to matter tho is the valve events.
Old Oct 29, 2006 | 11:43 PM
  #24
onebadrubi's Avatar
h/o still timing out to read agian and agian and agian and agian and aigan. haha j/k.
THanks sport side that helped understand a little more.
Old May 4, 2007 | 03:20 AM
  #25
WODY's Avatar
that lsk 223 .636 112 is the exact cam richard sold me on for my l92/l76 setup. sorry guys not in yet.
Old May 4, 2007 | 03:43 AM
  #26
bluecajun5.3's Avatar
11 Second Truck Club
sweet man!
keep us utd
calsdad
Jun 14, 2023 11:07 PM
00loudchevy
Dec 3, 2015 05:54 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Slammed silverado
Sep 28, 2015 06:14 PM
vmaxpro
Sep 28, 2015 11:10 AM
