how to tell
Old Jun 24, 2006 | 09:50 AM
jus1975's Avatar
Default how to tell
How can you tell if your valves are adjusted correctly with adjustable rockers.
Old Jun 25, 2006 | 09:06 AM
litreddevil's Avatar
Banned
if it is running real stupid after putting adi.rockers on the back them off a 1/4 turn and see what happens.i have to reset my this week also.i check my evey other month
Old Jun 25, 2006 | 09:15 AM
Dock Rocker's Avatar
Also if it sounds like a sewing machine that is a sign as well.
Old Jun 25, 2006 | 10:51 PM
jus1975's Avatar
sewing machine sound is a sign of what? Good or Bad.
Old Jun 25, 2006 | 11:45 PM
If it is ticking or clattering that is bad..
Old Jun 26, 2006 | 12:37 AM
02sierraz71_5.3's Avatar
Adjusting Hydraulic Lifters for Proper Preload
In order to adjust the preload, the lifter must be properly located on the base circle or "Heel" of the lobe.
At this position the valve is closed and there is no lift taking place. You will need to watch the movement of the valves to determine which lifter is properly positioned for adjusting.
1. Remove the valve covers, and pick a cylinder that you are going to set the preload on.
2. Hand rotate the engine in its normal direction of rotation and watch the exhaust valve on that particular cylinder. When the exhaust valve begins to open, stop and adjust that cylinder's intake rocker arm. (Why? Because when the exhaust valve is just beginning to open, the intake lifter will be on the base circle of the lobe, the correct position for adjusting the intake.)
3. Back off the intake rocker arm adjuster and remove any tension from the pushrod. Wait a minute or two for that hydraulic lifter to return to a neutral position. The spring inside the lifter will move the pushrod seat up against the retaining lock if you give it time to do so. (If you are installing brand new lifters they will be in the neutral position when they come in the box.)
4. Now spin the intake pushrod with your fingers while tightening down the rocker arm. When you feel a slight resistance to the turning of the pushrod, you are at "Zero Lash". Turn the adjusting nut down one half to one full turn from that point. Lock the adjuster into position. The intake is now adjusted properly.
5. Continue to hand turn the engine, watching that same intake. It will go to full open and then begin to close. When it is almost closed, stop and adjust the exhaust rocker arm on that particular cylinder. (Again, when we see the intake almost closed, we are sure that exhaust lifter is on the base circle of the lobe.) Loosen the exhaust rocker arm and follow the same procedure described before in steps 3 and 4 to adjust this rocker arm.
6. Both valves on this cylinder are now adjusted, and you can move on to your next cylinder and follow the same procedure again.
http://www.cranecams.com/?show=techarticle&id=2
Old Jun 26, 2006 | 09:07 AM
when you are doing the above mentioned task dont forget to take out the spark plugs it makes that whole engine turning over thing alot easier!
Old Jun 26, 2006 | 11:31 AM
jus1975's Avatar
The confusing part is that I have read different ways to adjust the rockers. On Vinci site there is a section for adjusting crane rockers and it says do the same except turn the adjusting nut until the roller bearing is not able to sping on top of the valve stem. Will this be same on all rockers or just those.
