HOW TO change valve springs on chev 5.3 ???
Old Mar 10, 2010 | 11:48 AM
jiar577's Avatar
Why not? Guys have been doing it for years and years...just be sure to leave some hanging out so you don't lose it in the cylinder, and make sure that the rope doesn't fray easily...
It's not the preferred method, but it works if you don't have access to an air compressor...
+1
I had to use the rope method on a couple of cylinders and worked like a charm
Stay away from the crowbar style spring compressors. I made my own version of "Tim's tool" (try a search) and worked perfect.
Old Mar 10, 2010 | 11:55 AM
01SilvyZ71's Avatar
i used the top dead center method and it worked fine. i didnt even put a piece of rope in but the valves would slip like 3/8" into the cylinder if you pressed down on them.
Old Mar 10, 2010 | 12:03 PM
Badboy464's Avatar
Whatever you do don't buy the tool that grabs the spring and you turn the top down. I spent four hours trying to use that tool and it was the biggest PITA ever. deffinatly buy a good quality valve spring tool. It will make your life alot easier.
Old Mar 10, 2010 | 05:58 PM
Ferocity02's Avatar
My valve spring tool of choice... of course it helps to have the heads off
Old Mar 11, 2010 | 09:40 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, it's a little tough to use that one while in the truck lol. I'll be using a similar compressor when I swap on some 1218's since my heads are currently on a shelf...waiting patiently
Old Mar 13, 2010 | 08:00 PM
gblauf's Avatar
Default HELP need bolt now
Alright so i tackled this today and BROKE a rocker arm bolt!!! Anyone know who might have these other than the dealer????
I was able to get the broke part out of head. I must say this was more time consuming than i thought and the spring tool was too long for the back cylinders, since the firewall curves up opver the motor so i cut 4" of the tool and it worked great. Took about 4 hours!!
Old Mar 13, 2010 | 08:23 PM
carolinaz71's Avatar
u ended up using the prybar style?
Old Mar 13, 2010 | 11:36 PM
TIM Z's Avatar
11 sec. Truck Mod
**** you have my luck.
I found some rocker bolts at the local salvage yard.
I endend up breaking another rocker bolt, trying to drill and tap the hole, and ended up having to buy another head.
But i have extra rocker bolts/arms now!
chopperloco
Jul 10, 2016 10:45 PM
bizle
Jul 22, 2015 07:31 PM
4B11T
Jul 13, 2015 03:48 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
Mzay
Jul 6, 2015 11:05 PM
