high torque starter
Old Jul 1, 2017 | 04:04 PM
terravast4's Avatar
Default high torque starter
Anyone running an aftermarket starter? After installing my 383 my starter was struggling to turn the motor over. I figured since it was 12 years old it just needed replacing. after installing the new starter i still have the same issue. the compression is at about 10.5:1. I wouldn't think this would be an issue but that starter looks so puny compared to the old school small block chevy starters.
Old Jul 1, 2017 | 04:09 PM
FFDP's Avatar
Random question, how is the voltage to the starter?
It is possible there is a large drop when you crank it and it's not getting full power to the starter?
Old Jul 1, 2017 | 04:11 PM
terravast4's Avatar
i didn't check. but i did relocate the battery to the truck bed
Old Jul 2, 2017 | 02:40 AM
smokeshow's Avatar
Mod with training wheels
What gauge battery cables did you use? I did a battery relocation to the bed area on my rcsb back in the day and ran 00 without issue. Probably added 20lbs worth of copper weight to the truck though.
Old Jul 2, 2017 | 11:58 AM
terravast4's Avatar
its good cable. i bought a kit from summit. its some thick ****
Old Jul 2, 2017 | 05:51 PM
MikeGyver's Avatar
Like how thick? Moving your battery twelve feet from the starter will really drop voltage. It definitely is not your compression. My engine has the same CR as yours and is bigger, and it cranks like stock. You didn't add a shitload of cranking timing, did you?
Old Jul 3, 2017 | 10:22 AM
terravast4's Avatar
the cables are 1 gauge. and its mounted right behind passenger cab. As far as cranking timing i am not sure. Nelson did a temporary tune, we are about to add an aeromotive fuel cell under the bed then we can dial in the tune for the additional fuel. Maybe its something in the tune he can check on
Old Jul 5, 2017 | 09:39 AM
Drspencer's Avatar
5 Year Member
Is the ground cable less than 12" long...? That's just as important as the power cable. Maybe stick another ground somewhere.
Old Jul 5, 2017 | 09:41 AM
madmann26's Avatar
My TMS motor is 10.75:1 CR.
The stock starter spins it over just fine everyday.
Old Jul 5, 2017 | 11:07 AM
terravast4's Avatar
maybe just not a good ground. i will check that out
