High compression cammed 4.8
Old Dec 8, 2010 | 12:29 PM
Yellowsierra's Avatar
Default High compression cammed 4.8
Hey guys,
Its time to do alittle work to my RST silverado. Its a fun little truck but with the stockish 4.8 its liking the go fast fun. Expecially since my GTO has a 390LS2 stroker with a maxed out D1 procharger... Im wondering how far I could go with trying to get some compression out of the 4.8. Im thinking of milling the heads .045" or so getting the heads to 54-55 cc along with a cometic .027 x 3.910 head gasket. That will put the CR to around 11-1!
Then for a cam I was thinking of a TSP 224/224 581 581 on a 112.
The only concern I have is PTV clearence. I have a 4.8 laying in the garage and I figured I could use it for mock up. I will stick the cam in the mock up 4.8 measure PTV clearence ect ect ect...
Whats the min. PTV clearence needed? .050"? .060"?
I figure if Im able to get 11-1 CR with the heathly 224 cam it should run pretty well.
What do you guys think?
Justin
Old Dec 8, 2010 | 08:05 PM
RSTinOKC's Avatar
Purely opinion here, but I think 4.8's are meant to spin high rpm's and fuel turbos.
The rice burner of the LS family if you will lol.
Old Dec 8, 2010 | 09:03 PM
Beatdown Z's Avatar
Laid Back
I agree that 4.8's should have a turbo hanging off the side. But, a high compression 4.8 would perform well. Just make sure you pick the best cam possible. I think you could do better than a TSP 224...
Old Dec 8, 2010 | 09:09 PM
BlackGMC's Avatar
Resident Retard
Mine does well i am about at 10.5ish. But alot smaller cam spinning to 7k. I had a 222/224 cam with the same set up But i went faster with my current cam.
Old Dec 8, 2010 | 09:25 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
That headgasket is going isnt going to work with a stock shortblock.
Old Dec 8, 2010 | 10:56 PM
I just found a great deal on a LQ4.... I might have to say goodbye to the little 4.8
Old Dec 9, 2010 | 03:21 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Do the 6.0
Old Dec 9, 2010 | 07:30 PM
03_SS_22's Avatar
Originally Posted by twolow02fransen
Do the 6.0
+1 there are so many options with the lq4...
Old Dec 12, 2010 | 09:49 PM
sand man's Avatar
arghhhhh 6.0's are cheap over there...damn they sell'em here for arround 3000-4000$
Old Dec 12, 2010 | 10:10 PM
Yeah the one I found is under $1500 and already has a TSP 228r cam kit in it! Should have a nice sound and power and still be a good Daily driver motor...
