Help picking cam for 5.3 s10
Old Oct 27, 2009 | 01:37 PM
L$X$10's Avatar
Default Help picking cam for 5.3 s10
Im in the process of installing a FLT lvl4 trans with a Yank ss3600 into my 5.3 s10. I was thinking it would be the right time to install my cam as well. The truck is a reg. cab weighing about 3500lbs with me in it. The setup includes:
>Ls6 intake manifold, CAI, ported TB
>Sanderson shorties, X-pipe, dualindualout muffler(no cats)
>3.42 gears, A.R. Irocs 18"x8", Nitto555(275/40/18)(rear),
>50,75 or 100 dry shot
I was looking into the TR-220/220 112 because of the great numbers and ETs that 5.3s are putting out with this cam, but Im now looking into a custom grind to make sure it will match my setup and make the most power without going over board for a daily diver.
Any advice would be appreciated.
Old Oct 27, 2009 | 01:51 PM
Wyttrash96's Avatar
I hate my cats
There's lots of threads up about this. I'd think you could go further than a 220 with that loose convertor and light little truck. Maybe a 224 or even a 228 like 00Chevyscott is using maybe?
Old Oct 27, 2009 | 03:25 PM
stephenok711's Avatar
I've got a 224/230 110 lsa custom grind for sale that would be badass in that truck. ALso got valve springs and adjustable timing set and necessary gaskets
Old Oct 28, 2009 | 11:33 AM
budhayes3's Avatar
PT's Slowest Truck
As mentioned, with that converter I'd go bigger than a 220, and I'd get some head work done too. Something in the 224 range would compliment a 3600 verter.
Old Oct 28, 2009 | 12:32 PM
L$X$10's Avatar
I dont think i could really run that 110lsa all day...ill start looking a little more into the 224s..and about how much money am i looking at spending on head work?
Old Oct 28, 2009 | 05:29 PM
budhayes3's Avatar
PT's Slowest Truck
Head work depends on where you go...it could be a couple hundred from someone local, to almost 2 grand for a nice cnc'd set of heads. I like WCCH (sponsor, link to right>>>). I have a set of their StageII 317's that will be going on my LQ9 when I build it. They have some offerings for 5.3's also, including the new Edelbrock's that I believe they have worked.
For your daily driver I'd look for something on a 112-114 LSA. The TR224 is a proven performer in the 6.0's, and some have run it in their 5.3's. You could also do a Comp 222/224 .56x/.56x 112...(can't remember the lift but it's on Comp's website) the verter is a little more than that cam needs, but will still work well. Zippy (who is a member here and an Admin at SilveradoSS.com) is running that cam in his 5.3 and likes it a lot. Can't remember what converter he's running though...
Old Nov 2, 2009 | 09:55 AM
L$X$10's Avatar
Thanks for the help
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Go5.3tt06
Jul 20, 2015 08:00 PM
06 4.8
Jul 15, 2015 07:17 PM
Aboss
Jul 9, 2015 10:28 AM
