Help with LQ4 cam selection
Old 07-30-2010, 09:54 PM
PT's Slowest Truck
budhayes3's Avatar
The 116 LSA won't give greater low end torque, but a broader torque curve, actually the tighter LSA should come on a little sooner, but also peak sooner. I like the slightly tighter LSA actually...I went to the website and looked at the specs. The butt-kicker is listed with a powerband that is 200 rpm higher than the Ultra torque, which is interesting since for years now it's been repeated here that a tighter LSA will bring the power on sooner, but also peak sooner. I guess with all other things being equal though, the extra overlap provided by the tighter LSA will actually move the powerband up higher? They're both so similar that I don't believe that you could go wrong either way...
Why did Roger say that the buttkick would be better for your needs?
Old 07-31-2010, 08:54 AM
RhinoSS's Avatar
He did mention that the curve would be broader on the butt kicker. I wanted to get a little more info, but he seemed busy when I called. I didn't want to eat up too much of his time. I'll be calling back on Monday to place the order, at that time I'll see if I can get some more info.
Old 07-31-2010, 10:29 AM
PT's Slowest Truck
budhayes3's Avatar
That doesn't make sense, the wider the LSA, the broader the torque curve, and tighter should equal more peak torque at a lower RPM
Blue03sss
03-07-2019 05:06 PM
GrooveCityZ71
08-31-2015 12:05 PM
darnie
08-10-2015 10:25 AM
jaypowe11520
07-29-2015 07:59 PM
NuckenFuts
07-09-2015 08:45 AM
Quick Reply: Help with LQ4 cam selection
