Help? Lifter not pumping/filling up
Old Mar 16, 2013 | 03:55 PM
patofdzb's Avatar
Originally Posted by smokeshow
No thats not what he meant. It's just not as precise on that block. You should be using all same length pushrods, otherwise you have other problems to address. It is best to check the length though so you aren't on the extreme sides of lifter preload, not enough causing valvetrain slack or too much causing valve hang and lower compression.
oh okok, so its gotta be all same lenght. I´ll have to find a length checker then.
I really hope its this and not a lifter, i´d rather buy new pushrods, than remove heads again and change lifters.
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
zblee
Sep 19, 2015 06:33 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
