Help fast please.. Head bolts
Old Nov 2, 2006 | 04:46 PM
Mangled03gmc's Avatar
Baltimore Whore
Default Help fast please.. Head bolts
Hey guys need to know if i can use ls1 head bolts on my 05 6.0.. I am pretty sure i can. Also what is the head bolts that are different lengths like x amount of bolts are a length, the rest are different ,for these engines.. I threw the stockers out, for some reason it has slipped my head.
Thanks John
Old Nov 2, 2006 | 06:09 PM
1SlowHoe's Avatar
Destroyer of Transmissions
The 05+ blocks use different lengths than the 04 and older. The bolts that were 6 1/2" long are replced by the bolts that are 4 1/2" long. I cant remember the exact count and I don't have any heads laying around to look at. If you call for a new set make sure whomever you order from knows its for an 05 block and knows they are different lengths.
4 1/2" GM part number 12560745 Sold in a 5 pack
2" bolt 12558840 Sold in 5 pack.
I have a set if you're interested. I orderd them then went with ARP.
Old Nov 2, 2006 | 06:35 PM
Baltimore Whore
Ok that kinda cleared it up, so the 05+ use shorter bolts along the exhaust port side(5 bolts) and in between the rockers(5 bolts), the bolts that run along the top(intake side5 bolts) are still the 2 inch bolts... I am going with arp bolts and see there was a differnce, needed to know.. what was the reason for them going to a shorter bolt, will a 6 1/2 still work??not that i am going to try but just curious.. Thanks JOHN
Old Nov 2, 2006 | 06:41 PM
1SlowHoe's Avatar
The bolts wont sink all the way the into the block. The stick up about 3". If you call WCCH ask for part # LSX 134-3610 should be about $100.
SPONSOR---->
Old Nov 2, 2006 | 06:50 PM
Baltimore Whore
SPONSOR---->
Acutally i found them cheaper from a non sponser but thanks much for the help as i would have been pissed if i got the wrong ones. Do you or anybody know why they went to a shorter bolt for the 05+ 6's.. Thanks again much help JOHN
Old Nov 2, 2006 | 07:02 PM
1SlowHoe's Avatar
Do you or anybody know why they went to a shorter bolt for the 05+ 6's?
No idea. I didnt even know they did it until I tried to put my new bolt in Then I had to overnight the ARP set in to get running.
Old Nov 2, 2006 | 07:19 PM
Baltimore Whore
OK again thanks alot.. JOHN
slowlsx
Aug 10, 2015 05:33 PM
Denali08
Aug 9, 2015 04:34 PM
signguy62
Jul 27, 2015 03:42 PM
fat tony157
Jul 16, 2015 12:35 PM
