HELP which cam?
HELP which cam?
hey guys,
Iam having trouble deciding on which cam i should go with. I like blue cajun5.3 Idle clip he has. it sounds freaking awesome. I am stuck between two cams 220/220 .551/.551 112lsa and a 224/224 .581/.581 112lsa which is going to work better for a DD and also which will sound better at idle? iam wanting to get a very lopely idle that sounds very good Also going to mill stock heads .030 and install double springs and a little larger intake vavle and exhuast vavle. A local shop is going to set my heads up. O yeah they are going to port and pl. the heads aswell What do you guys thank????
