Head and Cam Swap
Old Jul 16, 2006 | 12:10 PM
truckman9's Avatar
Default Head and Cam Swap
I am fixing to swap out the heads, cam, and intake on my 5.3 with everything from a 2002 Z06 corvette. I was wondering I have seen people swaping pushrods, springs, rockers, etc.? Do I need to do this for it to run right? Ir can I just use everything off my old 5.3 heads?
Old Jul 16, 2006 | 12:22 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Wont the head swap cause a drop in compression, loss of low end? Valve size different?
Old Jul 16, 2006 | 01:11 PM
truckman9's Avatar
I am running a supercharger so I need to lower the comprssion
Old Jul 16, 2006 | 01:13 PM
trever1t's Avatar
That makes more sense!
Although you don't need to drop compression unless you want to run high boost. I am going S/C with 9.9-1 CR with 7-8lbs next week.
Old Jul 16, 2006 | 01:15 PM
tdrumm's Avatar
Are you getting fully assembled LS6 heads? If they are, use their springs and valves, and get some hardended 7.4" pushrods.
Old Jul 16, 2006 | 11:41 PM
truckman9's Avatar
the heads that I got are complete except for the rockers
Old Jul 17, 2006 | 05:54 AM
tdrumm's Avatar
Then you are good to go. Use the rockers that come off your stock heads. They're the same as the stock LS6 rockers.
Old Jul 17, 2006 | 08:59 AM
truckman9's Avatar
ok thats what I was wondering thank you so much. What about pushrods?
Old Jul 17, 2006 | 09:52 AM
tdrumm's Avatar
The stock ones will work, but I think you're better off getting a set of aftermarket hardended ones. There only ~110 new, but you could probably find a set in the 70-80 range used.
Old Jul 17, 2006 | 01:05 PM
truckman9's Avatar
ok thank you so much you have been extremely helpful.
