gotta question
Old Oct 17, 2009 | 01:56 PM
LsxCody's Avatar
Default gotta question
Someone told me that I need to use some kind of substance when I use a multi layer. Steel type head gasket. I have never heard this before. I have some fel pro multi layer gaskets. Can I just put them on without anything. Just wondering.
Old Oct 17, 2009 | 02:07 PM
dirt track racer 81's Avatar
last couple motors i built i sprayed some copper coat on both sides
Old Oct 17, 2009 | 02:20 PM
LsxCody's Avatar
Well I already put the heads on and I didn't use anything. Just worried that I missed something and they will leak. Is it a must
Old Oct 17, 2009 | 03:51 PM
hirdlej's Avatar
No it's not a must. If your surface prep was good you'll be just fine. I've never used any spray gunk on any of my gaskets ever. If your block deck surface is true and the heads have a good flat surface you're going to be fine.
Old Oct 17, 2009 | 04:27 PM
LsxCody's Avatar
Thanks for the help
Old Oct 17, 2009 | 07:26 PM
it wont hurt. my 370 i just put the gaskets on and clamped them on. your good to go
andrewlong
Nov 9, 2016 09:38 AM
andrewlong
Sep 8, 2015 10:25 PM
Forcefed81
Sep 8, 2015 10:02 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
