Good cam for 5.3 no tq conv
Old Nov 6, 2010 | 08:39 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by dmelvin
Time to bring back this old thread. I'm looking at getting this cam (the 215/223 .604/610). How would this work for a DD... Anyone running this in a DD? How much MPG did you lose?
I think that would be good in a 5.3, similar specs to the Vinci Trucker with a bunch more lift. I'd run at least a 2600 converter though. What's the LSA on that cam...are those the new Comp LSR lobes, or is that a custom grind? As for MPG loss, I don't think that it would be too bad if the tune is spot on, but there will be some MPG loss.
Old Nov 6, 2010 | 08:45 PM
  #22
Daryn's Avatar
Formerly darynC-10/23/10
as logn as you keep it under a 224/224 duration your fine. i drove a tr224 on a stock converter for a while.
Old Nov 6, 2010 | 09:27 PM
  #23
dmelvin's Avatar
It's a LSR lobe it's actually the mildest of the LSR cams. (Grind number 54-455-11). LSA is 112, don't know about any advance though, I haven't found a cam card anywhere for it yet.
Also, anyone running an LS1/LS6 intake with a bigger throttle body to really help it breathe in the upper revs? I figured with a cam like this I figure letting it breathe easier wouldn't be a bad thing, even if it costs me a bit on the low end.
Old Nov 6, 2010 | 09:45 PM
  #24
budhayes3's Avatar
PT's Slowest Truck
Do you know the ICL? If you have the ICL, you have the advance...Advance=LSA-ICL
*EDIT* Checked Comp's website, 107 ICL, so 5* advance
Old Nov 6, 2010 | 10:20 PM
  #25
dmelvin's Avatar
Well, that solves that mystery. So what do you guys think? This cam with a stock converter for the time being, and work my way towards intake/90mm Throttle body, LT headers, maybe a 2600 or 3000 stall?
Old Nov 7, 2010 | 12:02 AM
  #26
Bigschwerm's Avatar
I say go for it...I was was running my Custom Ground version of the Vinci Trucker Cam (Predator Grind) 216/224 .551 .551 on a 110 LSA and it ran very well with the stock Verter
Old Nov 7, 2010 | 01:13 AM
  #27
matthew20061's Avatar
I was/still am, running that cam in my 5.3L and absolutely love it. Works perfect with the stock converter, I'm sure there would be gains with a small converter but definitely not worth changing in a DD. Honestly I don't check the mileage to much but it got 17MPG with a 30min drive both way out to the drag strip, ran two passes, then drove back. Filled up and it got 17 so I would say it's pretty good on gas with the spot on zippy tune I got.
Old Nov 7, 2010 | 10:11 AM
  #28
budhayes3's Avatar
PT's Slowest Truck
Well there ya go, nothing like real life results to tell the tale I've heard that Zippy does real well at maximizing a cam's potential in both the power and efficiency departments...word is that he can make even the most aggressive grinds sound stock Once again it goes to show the importance of a spot on tune
I gotta say though, as well as my baby cam did with the stock converter, the fun factor increased %1000 after I got my Circle-D 3k in there. Even if I was on the stock cam I'd want a converter in one of these GENIII trucks, just my opinion If just wanting a cam swap though, it's good to know that there's no need to have to pull the trans in this situation.
Old Nov 7, 2010 | 02:21 PM
  #29
I'm sure your right on about the converter, I'm going to find that out soon, with the new Circle-D I ordered for the 6L swap!
Old Nov 7, 2010 | 08:26 PM
  #30
budhayes3's Avatar
PT's Slowest Truck
You're going to love it Matthew...I haven't owned a vehicle with a converter since 99 and forgotten how fun it was to drive. Now that I have one again, I don't know how I survived without it for so long! And just like everybody says, once you get used to it, you want more!
