first time mods question/help me
Old Oct 17, 2019 | 11:56 PM
sammysafety's Avatar
Registered User
Default first time mods question/help me
I have a 2012 silveraldo ltz daily driver at about 152k miles. recently its been burning oil and blowing smoke during afm on. I wana do these mods my self and not hire a shop cause i wana learn how to do it myself. my question is when buying a afm/dod delete kit (currently looking at tsp site) what type of cam should i look into buying? kinda want a lil bit of performance but i wana keep it to where i dont start breaking things cause i do wana buy donor engine to build on the side while i learn on this one
Old Oct 18, 2019 | 09:31 AM
Summitracing's Avatar
LS1Tech Sponsor
If this has VVT are you deleting that as well? This would open up your camshaft options if you don't have or are deleting VVT. We have DOD delete kits as well as VVT delete kits.
If you're deleting VVT we would recommend one of our stage 1 camshafts. There are three versions of the stage 1. The rv/tow, drop-in, and hi-lift. These will all provide a good variety of low-end torque with good to very strong mid-range and top-end power. With the mileage you have on this engine it would be a good idea to replace the springs. We have the LS6 NAL-12499224 that would work well with any of those stage 1 cams. Those springs will work with your stock retainers.
Old Oct 18, 2019 | 06:09 PM
Registered User
my vin- 3GCPKTE79CG149782
i believe i do have vvt i'm not sure what deleting it would open me up too as for right now. I'm just trying to get lil more lower end power with a stock converter i plan on picking up the hptuner plan on maybe having someone remote tune
Old Oct 21, 2019 | 11:39 AM
LS1Tech Sponsor
Thank you for providing your vin. You have the LC9 engine which has VVT. Keeping VVT will help fuel economy and driveability. Deleting VVT will help performance by keeping your right foot and engine response in sync.
If you wanted to keep VVT we would recommend the Comp Cams's high-lift CCA-189-400-13. This will provide good torque off idle and improve power throughout the powerband. This will require a phaser limiter for the cam phaser. You would need the CCA-5460 phaser limiter kit. You will not be able to use stock springs with this cam. Comp recommends the CCA-26918CS-KIT spring kit.
If you decided to delete VVT as well you would need a VVT delete kit. To use a 3 bolt cam such as one of our Summit Pro LS cams you would need CMB-09-0027. Or if you wanted to stick with a single bolt cam then you would need the CMB-09-0028.
Any of the previously mentioned Summit stage 1 truck cams or the above-mentioned Comp cam will work with stock gearing and converter. You have a good plan of action getting HP Tuners and having a tuner email you a tune.
Old Oct 22, 2019 | 01:08 AM
Registered User
thanks i think i have a shopping cart put together based off your suggestions. probably will keep the VVT, you've been quite helpful this far thank you!
im curious how does rod length get configured in these builds or is that something ill have to order later after i measure each one?
Old Oct 22, 2019 | 09:22 AM
LS1Tech Sponsor
No problem. Happy to hear you liked our suggestions and are getting a shopping cart together.
As long as the engine is stock and the heads have not been milled you could go with 7.400 in. pushrods. This is as long as the CCA-189-400-13 cam is being used. We have quite a few upgraded Chromoly options available. We would recommend the Summit Racing SUM-1457401, Brian Tooley Racing BTC-PR7400312-16, or Cam Motion CXM-PS174001204.
Old Oct 22, 2019 | 11:11 AM
Alvin@PCMofNC's Avatar
Truck Sponsor
Since you have to swap out the cam anyway when you delete DOD, it's a great time for an upgrade. If you don't have any other mods, our Stage 1 cam does great (link). If you have more mods we do have larger cams as well but this is a great starting point. We also offer tuning to get it running correctly (delete DOD And/or VVT, set it up for the cam/other mods you might have). These trucks respond really well to modifications.
Old Oct 26, 2019 | 11:56 PM
Registered User
since ill be down by it should the oil pump be replaced? even if i dont have issues? it is pretty high mileage after all
Old Oct 27, 2019 | 12:25 AM
FFDP's Avatar
Sometimes if it ain't broke, don't fix it is the name of the game. It may live on forever or it may take a dump in 50k miles but a new pump could do the exact same.
If you do, just buy a new stock pump. No need for any of those aftermarket high volume pumps.
Old Oct 27, 2019 | 12:59 AM
Registered User
wouldnt it be more like preventing a worn out part from failing? i get what your saying and i live by that moto but oil pick up is one of the most essential parts. im not sure im not seeing oil pressure drop or anything either so idk
