E3!!! Hype or Not ??
Old Sep 24, 2006 | 10:29 PM
icedenali's Avatar
Default E3!!! Hype or Not ??
hey guys!
i'm pretty sure y'all heard about E3, they claims engine will gain 6-12% plus better MPG??
has anybody intalled E3?
i have them ready to install, i'm waiting for my valve cover spacer!! 1.8 rockers arm won't fit into valve cover without spacers. also need need long spark plug wires!!!!
Old Sep 24, 2006 | 11:14 PM
Stoichiometric's Avatar
Is E3 a spark plug? I have not heard of it myself.
Old Sep 24, 2006 | 11:18 PM
nonnieselman's Avatar
ive heard of them, but i dont think i will pay that much for a plug... i like the $1.20 TR55s.. well it will be TR6s soon though
and i dont think they will net that much.. IMO
Old Sep 25, 2006 | 05:25 PM
icedenali's Avatar
I got them installed today. I replace NGK TR55, i notice engine idle much smoother than TR55.
as Far as performance, I CAN'T TELL if I gain or not, but definately engine running smoother and better..
Old Sep 25, 2006 | 05:34 PM
Do the E-3 plugs have 3 ground straps on them?
Old Sep 25, 2006 | 06:35 PM
thunder550's Avatar
High on diesel fumes
What 1.8 rockers did you get? My Vinci/Crane 1.8's fit with no modifications.
Old Sep 25, 2006 | 08:27 PM
budhayes3's Avatar
PT's Slowest Truck
...I don't think you'll see that much difference from spark plugs in these GENIII engines unless your old plugs were worn or were incompatable plugs. I've tried the factory platinums, Denso Iridiums, and NGK TR55's, and didn't notice a difference between the three...and the factory plugs that I removed were inconsistently gapped ranging from .040 to .065, straight from the factory too.
I have heard of folks having negative results with certain plugs in general....Bosch (especially when used in GM's), and Champions (when used in anything that didn't come with them as original equipement...they do work in Chrysler/Mitsubishi products), are some companies that come to mind.
Old Sep 25, 2006 | 08:56 PM
Good information, the platinum tips fall off of the stock plugs sometimes too.
Old Sep 25, 2006 | 09:13 PM
icedenali's Avatar
E3 are noticeblely quiet! WOW!!! I felt little rough idle with TR55.
As far as Gain HP, can't tell if I gain or not. it's pretty hard to tell little HP gain. Definately not lost it for Sure.
it's made out of COPPER and it's much cooler than platium or iridium
my trucks running much smoother and quieter then with NGK TR55.
I think it's worth it to invest 50 bucks for it.
I used PRW 1.8 rockers arm.(got it from RICHARD) WCCH. they look like comp cam 1.85 rockers arm. they are very good!!!!!!!
Old Sep 26, 2006 | 04:02 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
How do you gap those?
