Dynoed my 427ci Truck
Old Aug 28, 2009 | 11:09 AM
  #41
Denali08's Avatar
So, if I keep the same cam and just swap to L92 heads/intake, I should see improvement and peak hp should happen at higher rpm.
Old Aug 28, 2009 | 06:42 PM
  #42
supersub's Avatar
here is the dyno sheet of mine with the WCCH L92's with a 229/239 dur cam using the stock truck intake.
Old Sep 1, 2009 | 06:10 PM
  #43
Denali08's Avatar
What cc of L92 heads did you run and what pushrod length? Who spec'ed your cam?
I bought a complete L92 intake with fuel rails and DBW throttle body. I also bought Drx adapter harness.
I am still not sure if I should swap my TR224 or keep it when swaping to L92 heads. If I swap the camshaft, it will be 236/342 and I will get Vig 2800 or 3000 stall TC.
Old Sep 1, 2009 | 06:35 PM
  #44
supersub's Avatar
I want to say 76cc, the pushrods are .050 longer and i spec'd the cam out. I used the same intake with the above posted dyno.
I would recomend trying your exsisting cam first before the other. Our trucks are not very light.
Old Sep 1, 2009 | 11:25 PM
  #45
2001CamaroGuy's Avatar
wow, 400hp/450tq is really quite pathetic (no insult intended) from 427CIs.....
get rid of:
- cam
- heads
- intake
- manual cooling fan
Old Sep 2, 2009 | 12:30 AM
  #46
Spoolin's Avatar
GFYS and STFU
Well when you think about it it's about 500 shaft hp and 550 tq. That's about par with a Z06 so it's not alll that shabby
Old Sep 2, 2009 | 12:40 AM
  #47
ForcedTQ's Avatar
Exactly, actually better than a ZO6 for a truck, being that you have the ~550 lbft of torque!
Old Sep 2, 2009 | 12:50 AM
  #48
Denali08's Avatar
My truck is only 4290Ibs being RCSB stepside 1500. If I can avoid the cost of the cam $400+cam installation cost, it would be better. But I am afraid to go back again and redo the cam.
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
NuckenFuts
Jul 9, 2015 08:45 AM
