Dropping off block at machine shop
Old Dec 8, 2012 | 10:47 AM
  #21
sand man's Avatar
sexy , you might want to go with dry sleeves
Old Dec 8, 2012 | 06:01 PM
  #22
phasemaster1's Avatar
When you build an Iron 5.7 Block you need to be sure the 5.3L block can take that much boring. Some blocks have core shift and can not be bored that much. The only way to know is to have it sonic checked. There have been a few members that decided to bore any way and ended up with a scrap block.
So in other words wait to buy the pistons until you have the block checked out. Some companies will not accept returns on Pistons at all. Others may charge a restock fee.
Phasemaster, if your comfortable with the price and the shops work, then go for it. Some of the required tools can easily cost the price they quoted you.
I kinda jumped the gun on the pistons since I told them I bought them they told me to bring them in to measure and sonic check it. The guy next door to them has a ton of ls stuff and builds them. When I asked him to give me a price on assembling the short block he said he only does complete engine because he warranties them. Come to find out I ask the machine shop next door who does all his machining if they can assemble it and told me they assemble all of the ls short blocks for the guy next door.
Old Dec 14, 2012 | 08:03 PM
  #23
Well just got the short block back and everything looks good. Was wooried that the rotating assembly wouldnt be balanced since they had some one else do it. Check the crank and they added weight to it. Now only time will tell if they did a good job. my fingers are crossed.
Old Dec 14, 2012 | 09:33 PM
  #24
1FastBrick's Avatar
Custm2500's Rude Friend
Funny how that works isn't it.
It's not uncommon for some shops to send out the balancing. In some cases it can be time consuming and the average rebuild doesn't always need it. I am sure you will be fine.
We have independent balance shops out here too. We also have a guy that specializes in Rod reconditioning. These guys all do other stuff too.
Old Dec 15, 2012 | 02:42 PM
  #25
silver-mod-o's Avatar
Hunt&Fisherator
I've had good luck here lately with machine shops doing exactly what's asked. Wasn't the case a few years back.
As far as the block not handling the overbore, some stock blocks will badly go over stock, however... We built a 5.3 block with 4.00 stroke and 3.910 bore not long ago, she was definitely a runner in a Miata with good heads/intake/camshaft setup with about 11.5:1 compression
  #26
Hunt&Fisherator
As far as the block not handling the overbore, some stock blocks will barely go over stock, however... We built a 5.3 block with 4.00 stroke and 3.910 bore not long ago, she was definitely a runner in a Miata with good heads/intake/camshaft setup with about 11.5:1 compression
silver-mod-o
18
Aug 25, 2015 08:18 AM
shupe
Aug 5, 2015 06:45 PM
low2001gmc
Jul 23, 2015 05:10 PM
jmarkway
Jul 18, 2015 09:23 PM
4B11T
Jul 13, 2015 03:48 PM
