Double Checking: Head milling
Old Oct 27, 2006 | 06:11 PM
joshluther's Avatar
Mine are .055 and no problems. Oh and 224 .581 112Lsa is really tight
Old Oct 27, 2006 | 06:12 PM
Derek @ EDO's Avatar
FormerVendor
how much of an increse in power would you get milling .50 off?
This is a free mod for me, Have the machine to do it with
Old Oct 27, 2006 | 11:09 PM
you raise your compression about a full point so you get more power and economy that way
Old Oct 28, 2006 | 09:56 PM
FarmerBeau's Avatar
Sexy Party Mod
Nope, Using Harris Engine and Grinding in Baytown. I dont trust the country yayhoos out in College Station.
Hey Joshluther: What do you mean by it is tight with that cam? I assume you are talking about P to V clearence but did you check it? Our pistons are dished so thats a little added clearence.
Old Oct 28, 2006 | 10:01 PM
isnt baytown far from tomball? BTW, i understand the city of tomball turned into lake tomball....
Old Oct 29, 2006 | 01:50 AM
02sierraz71_5.3's Avatar
Ive never seen how the intake wouldnt fit even if you took 100 off, there is plenty of space between the valley and the bottom of the intake plus no matter how much you take off the angles between components wont change.
BTW my cam is 112/112 222 .566 lift 2.00/1.55 valves
the valve job is well worth the money
Old Oct 29, 2006 | 05:01 AM
joshluther's Avatar
Ptv minimum clearance should be .080 on the intake and .100 on the exhaust.
and I think I had .080 and .090, but with titanium valve-train components and dual springs rated at 377 lb/ins. it should be OK
Old Oct 29, 2006 | 09:22 AM
Sport Side's Avatar
Josh, what is the ICL of your 224-112 cam and if adjusted during the install, what was it installed at?
Old Oct 29, 2006 | 09:26 AM
the angles wont change but if you mill the heads, the bolt holes on the head will sit lower than the bolts holes on the intake. thats where the problem comes in
Old Oct 29, 2006 | 11:37 AM
tdrumm's Avatar
Also, what size valves are you running?
