dod cam
Old Jan 9, 2010 | 05:10 PM
CJ Hungus's Avatar
Originally Posted by CAPO
this is what i said , i have DOD not VVT , pcm shut off the 4 cylinder,s fuel ,spark and the valves , vvt pcm control the cam by phaser , icant remmber how many degrees maybe from 20 to 70 deg resulting in good MPGs
Also known as Active Fuel Management (AFM). I think you want to disable the AFM and get a regular cam and swap out the weak AFM lifters. I believe those are known to be the weak point. When getting more and more power, I would do things right.
Old Jan 9, 2010 | 06:56 PM
Tootall's Avatar
DOD does shut off the valves. It does NOT retard or advance the timing. So that means that you can use any off the shelf 3 bolt cam.
There are no specific cams that are "just for" motors with DOD
If your motor had VVT it would do the above, plus . . . advance and retard the timing with the cam phaser, which you do not have . . .
Old Jan 10, 2010 | 11:39 AM
CAPO's Avatar
there is DOD cams ,
http://www.neweraperformanceparts.co...=E&PKV=dodhi|0
http://www.neweraperformanceparts.co...=E&PKV=dodlo|0
on DOD setting you cannt go over 6400 rpms and no lift more than 583
this why the do DOD cams
MattOKC
Aug 18, 2015 11:30 AM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
Matt331
Jul 26, 2015 09:40 PM
EscaTruck
Jul 20, 2015 11:42 AM
