detonation
Old Mar 18, 2010 | 03:47 PM
supercharged680's Avatar
Unhappy detonation
hey there guys that stupid annoying noise cam up again tick tick tick at WOT.. it keeps going and coming.. for the last 3300 miles.. and i was pushing it not alot but everyday i mean.. anyways what should i do??? i called my tuner n he said he needs to reduce timing..
the HUGE problem is how do i knw that my engine isnt affected??? or affected..
Old Mar 18, 2010 | 04:02 PM
SILVERADO11's Avatar
may need to pull timing, may be running lean. you can pull the spark plugs see what they look like, look into the spark plug holes with a bore scope and see what all the tops of the pistons look like.
Old Mar 18, 2010 | 05:19 PM
hirdlej's Avatar
It'll be fine. That's how I used to set the total advance on my distributors. Advance until it rattles under WOT then back off a ****'s hair. I've never had a motor blow up due to detonation
Old Mar 18, 2010 | 08:20 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Using cheap gas? Was it fine on different brands of gas? Fine during the colder weather?
You can't really know that the engine is fine (without either pulling it apart or watching for symptoms over time), but if you reduce timing or run better gas and it stops rattling and makes no other noise, just watch for oil consumption etc.
Old Mar 19, 2010 | 06:44 AM
oil consumption is fine.. i use 95 octane < .......... i guess it was better during coler weather.. ill reduce timing to get started ill see if that makes any difference maybe check on the plugs as well
Old Mar 19, 2010 | 11:40 AM
budhayes3's Avatar
PT's Slowest Truck
I've seen severe detonation burn holes in pistons in race engines....but that was severe
Old Mar 19, 2010 | 12:57 PM
silveradoman's Avatar
Registered User
your engine should be fine though just follow the steps already posted and check those plugs
Old Mar 19, 2010 | 01:01 PM
Daryn's Avatar
Formerly darynC-10/23/10
ive seen 2 motors with holes in the pistons in the last 2 weeks from detonation , to much timing of course
Old Mar 20, 2010 | 12:30 AM
Wilde Racing's Avatar
How do I change this text
Checking plugs for rich/lean conditions on any vehicle that run stoichiometric closed loop, is a TOTAL waste of time, unless you are checking for plug damage.
Old Mar 20, 2010 | 09:02 AM
budhayes3's Avatar
PT's Slowest Truck
Could you please elaborate sir?
