Delay in oil pressure
Old Feb 24, 2020 | 07:30 PM
smokeshow's Avatar
Mod with training wheels
How are there so many o-ring problems... I've literally tried to **** it up and it never happens.
Old Feb 27, 2020 | 03:13 PM
RB04Av's Avatar
5 Year Member
That looks like the thick O-ring.
With that straight pickup tube, it needs the thin one.
The thick one probably doesn't go up into the pump body like it's supposed to, therefore might create a leak, if the pickup isn't absolutely straight up into the hole.
Not sure what the actual diameter of the 2 O-ring styles is.
As far as I'm aware it's not a year-model thing, or an engine-model. Seems to be kinda random. Although the non-straight version seems to be more common in general.
Pretty sure you can measure the bore of the pump and just get an O-ring of the appropriate thickness out of an assortment or something. You'd probably want about .010" - .015" of crush on it. Measure the hole, subtract the .875" of the tube, divide the result by 2, get an O-ring that's about .010" thicker than that. Or [gasp] [horrors] just buy the right thing, if it's available that way.
Old Feb 27, 2020 | 03:30 PM
vipergtrdj's Avatar
I got the correct oring and no more delayed pressure problem. First start in AM the gauge takes 2 or 3 seconds to register pressure but the top end noise is gone. After the first start of the day it makes pressure instantly.
Old Feb 27, 2020 | 04:28 PM
03sierraslt's Avatar
That’s a plus. Glad to hear.
Old Mar 4, 2020 | 04:32 AM
RySmDPT14's Avatar
Had the same issue when I turned my truck back to stock. The fel pro O-ring I got from advance auto was t correct. Had to use green one from GM for my 2012
Old Dec 9, 2020 | 07:09 PM
woodwright's Avatar
So I know this thread is a couple months old, but I have a 2005 6.0 that is doing this. Do you need to pull the pan to change the oring or can you just pull the front off?
Old Dec 9, 2020 | 07:27 PM
Ptdrumm14's Avatar
you can do it with taking front cover off and dropping the pan down to the front crossmember but it’s a pain and you risk pinching the o ring.
DV2000NJ
13
Mar 16, 2015 10:36 PM
DoubleTrouble
Jun 6, 2011 02:47 AM
jg53
Dec 10, 2009 06:16 PM
2k5Squirrel
Sep 26, 2007 01:13 PM
blkssncpt
22
Aug 2, 2007 11:29 AM
