deciding on heads.....
Old Jul 14, 2010 | 10:21 AM
  #21
just spoke with Matt @ Texas speed. Very knowledgeable on their products. Now i have to decide if i want a 5.3 or ls6 head. Thanks again Matt, hopeullt be orderin them in a few months!!
Old Jul 14, 2010 | 11:02 AM
  #22
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
as long as you can get the LS6 heads in 59cc which im pretty sure you can to up the compression to around 10.5.1 or more id say go the the LS6 heads imo
Old Jul 14, 2010 | 11:38 AM
  #23
Sales2@Texas-speed's Avatar
Former Vendor
Nice chatting with you too!
On his LS1 short-block and that cam, we can't get all the way to 59cc without flycutting pistons....but the extra cubes of the LS1 and flat-top pistons don't require 59cc to get the compression that high either.
Old Jul 14, 2010 | 02:03 PM
  #24
2001CamaroGuy's Avatar
Corrected:
I had "stage 3" heads on my stock LS1 and the valves just don't have the room to breath with such small bore. My heads flowed 330CFM on the intake (on a flow bench with the intake bolted on), but my friend had the EXACT same setup with cleaned up (just smoothed casting flash and such) stock heads and got a few more HP than I did (I got 400rwhp, he got 405rwhp). We both had the same LT headers, same cam (TR224/224 112LSA), both T56, both 3.73 gears, both had true duals, etc...
I'd say the Stage 2.5s would be as large as I would go.
Old Jul 14, 2010 | 02:07 PM
  #25
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by 2001CamaroGuy
I'm surprise nobody else has asked this..... but what size engine are you putting these on? Because you name says 4.8 and I see nothing indicating anything bigger, I'm guessing these are for a 4.8.
If so:
I would stay away from the "stage 3" heads for your setup. They will flow WORSE than a smaller valved head due to valve shrouding in the bore.
I'd say at most with the stage 2.5 head. Remember a 4.8 is a small bore and stroke so you don't need, nor can you use, huge heads. A good set of stage 2 heads will take a 5.7 till 7K and 450+ rwhp so unless you plan to spin to 1000000000000000000RPM, your 4.8 will be just fine. :p
The big thing will be getting more compression and a cleaned up port flow rather than bigger valves (with a small engine at reasonable RPMs).
Read his sig a little closer it says LS1 in bold letters.
Old Jul 14, 2010 | 02:17 PM
  #26
I stand corrected then...
My suggestion though still stands. Based on my experience (and others that I have spoken too), Stage 3 is just too big for anything smaller than a 4.060" bore or larger engine.
Old Jul 14, 2010 | 03:42 PM
  #27
Former Vendor
The problem is that there is no standard for what a Stage is on a head...our Stage 2 Cathedral port heads have 2.02"/1.57" valves...but a competitor's might have 2.05"/1.60".
But I'd agree the 2.08" valves in an LS1/LS6 casting are shrouded a bit much for a 3.90" or smaller bore!
Old Jul 14, 2010 | 04:17 PM
  #28
dlt76028's Avatar
Here's what I have to say about PRC heads...
https://www.performancetrucks.net/fo...d.php?t=456408
And that's with no tuning.
Old Jul 14, 2010 | 04:22 PM
  #29
1slow01Z71's Avatar
Your thread is one of the reasons I decided to pick up a set for my LQ4, damn good bang for the buck.
Matt everyone seems to be hung up on peak flow numbers, can you post up some tips for people in the market for heads to figure out what is best. There is a lot of voodoo about flow numbers that i think people have no idea about the different ways to skew them.
Old Jul 14, 2010 | 06:11 PM
  #30
Sweet!! yeah im def going with the PRCs. I learned alot in the 5 mins i talked to Matt.
