daytona prototype motor in a truck
Old Feb 16, 2008 | 05:39 PM
IMD's Avatar
IMD
Banned
Originally Posted by jkwalkercchs
imd---i think outside the box try it some time
thats great, try thinking outside the crack pipe instead.
Old Feb 16, 2008 | 05:48 PM
nightrunner's Avatar
Mr. Obvious
in the usable rpm range, a ****** honda will make more torque than that motor. there IS a reason no one has used that motor yet. that motor is setup to be run at very high rpms constantly, as in a road racing application
Old Feb 16, 2008 | 06:00 PM
jkwalkercchs's Avatar
crack does the body good
yea i know but i wanna a high revvin truck
ill just drive it around like im racing
Old Feb 16, 2008 | 06:06 PM
Mr. Obvious
then go ahead and do the build. and then the entire forum will laugh at you when you complain about spending money on a engine build and it doesnt make any power before 5krpms and takes more maintenance than an full blown dragster. there is a reason that no body on here daily drives a truck with a solid roller valvetrain.
Old Feb 16, 2008 | 06:12 PM
no my daily driver is now a sportster 1200 custom
whats the diff in this and a 4.8 turbocharged?
Old Feb 16, 2008 | 06:20 PM
Mr. Obvious
a 4.8 turbocharged, if a quality turbo kit is used, will maintain stock reliability, and with a properly sized turbo, start spooling at approx 2500 rpm and have full boost at 3500rpm and be MUCH faster than your proposed NA setup and get MUCH better fuel economy
Old Feb 16, 2008 | 06:22 PM
did u miss the post i made about i wanna go turbo???
Old Feb 16, 2008 | 06:23 PM
IMD's Avatar
IMD
Banned
ahh a sportster. that explains alot.
Old Feb 16, 2008 | 06:25 PM
whats wrong with sportster??
Old Feb 16, 2008 | 06:29 PM
Mr. Obvious
i did miss that part BUT, what is the point in revving so high when you have a turbo? i dont remember the exact problems but i have read about having problems when revving over 7krpm when FI is used. maybe problems with getting valve springs to support the presures and not let the valves float. also for much boost you will need down to around 9:1 or lower. also forget about a solid roller with a turbo
