Cylinder Head Qs
Originally Posted by Quik
personally i wouldnt worry about ported headswith a stock truck intake. its kinda like kicking yourself in the nutts. you cna only take in so much air and if your intake is restrictive then everything else is just blah. i would find an intake that allows enough air in to take advantage of the ported heads
or does anyone know???
by the way to stay on subject, why not not mill the heads?
Wouldn't milling the heads only increase compression by reducing the combustion chamber size? Couldn't you produce the same effect by using a smaller cc combustion chamber heads without milling?
sauldgold
07-23-2015 02:15 PM
