Counter Revolution Engine
Old Jun 2, 2009 | 04:09 AM
Spoolin's Avatar
GFYS and STFU
Thumbs up Counter Revolution Engine
While I was doing some research on my bike and what not I ran across a bike engine that seemed really ingenious and new. Been trying to do more research on it but thought I would share just in case someone knew more about it than I did. Anyone know anything about the Moto Czysz C1 bike w/ the counter-revolution engine?
Old Jun 2, 2009 | 08:00 AM
nonnieselman's Avatar
it sounds cool....
Old Jun 2, 2009 | 08:15 AM
hirdlej's Avatar
They were doing this (I don't know if they still were) on Nascar engines years ago. The advantage to this was the car would handle better through the high speed corners given the rotation of the engine causing the tires to bite into the asphalt more.
Old Jun 2, 2009 | 09:14 AM
blue2003ls's Avatar
They had a story about the bike and its development on Speed Channel a few weeks ago. I think it was called "Birth of a Racer". If you can find it it's definitely worth watching.
Old Jun 2, 2009 | 09:45 AM
SBTork's Avatar
wow that sounds interesting
Old Jun 2, 2009 | 12:36 PM
PathfinderJr's Avatar
Yamaha was once doing this with their MotoGP bike, the M1. I think those was the days when they still ran the Screamer firing order though. It had to do with the moment of inertia of the rotational mass of the crank and associated bits. They found the bike to be a better handler as a result. Don't know if they still use it or not the current M1 iteration.
Old Jun 2, 2009 | 01:04 PM
Spoolin's Avatar
GFYS and STFU
Yeah I found that movie and saw it, does a decent job of explaining it but am curious to know more about it.
Old Jun 2, 2009 | 01:14 PM
Spoolin's Avatar
GFYS and STFU
it sounds cool....
From what I gather they took an inline four and cut it in half, sinc'ed up the firing order on the two half's and ran one backwards so that one half counter acts the second half. With that design there was no need for balance counterweights, heavy flywheel, etc... and it therefore was super super thin.
The advantage achieved within a motorcycle frame was that there is no longer a tendency for the motorcycle to right itself when you get on the throttle when in a hard turn. The gyroscopic effect of the crank on most bikes causes a leaning bike to become upright in a corner if too much throttle is applied or if a driver is not strong enough to keep the bike leaned over. With this design the bike can remain in an hard turn and you could literally go full throttle and you would not have the bike trying to rip you upright.
Old Jun 2, 2009 | 01:30 PM
Spoolin's Avatar
GFYS and STFU
Here's an article I found...
http://www.motorcyclistonline.com/fi...990/index.html
Old Jun 2, 2009 | 05:19 PM
MikeGyver's Avatar
I think because the rule makers keep changing the engine size and configurations, even the factories are having trouble funding constant redesign. Czysz is now developing an electric bike.
http://www.motoczysz.com/club/
