Comp Cams 7955-16 vs Comp Cams 7638-16
Old Nov 29, 2007 | 06:56 AM
Superado's Avatar
11 Second Truck Club
Default Comp Cams 7955-16 vs Comp Cams 7638-16
what is the difference between these two sets?
PUSHROD SPECIFICATIONS:
7638-16
For Use with Guideplates: Yes
Tubing Diameter (in): 5/16 in.
Pushrod Material: Chromemoly
Top Tip Style: Ball
Bottom Tip Style: Ball
Intake Overall Length (in): 7.400 in.
Exhaust Overall Length (in): 7.400 in.
Quantity: Sold as a set of 16.
One Piece Pushrod: Yes
Oiling: Yes
Tapered: No
Tip Attachment: Formed
Top Tip Diameter: 5/16 in.
Bottom Tip Diameter: 5/16 in.
Wall Thickness (in): 0.080 in.
Heat Treated: Yes
7955-16
Top Tip Style: Ball
Oiling: Yes
Tapered: No
Heat Treated: Yes
Old Nov 29, 2007 | 10:24 AM
KevinF56's Avatar
looks like the exact same description to me...
call Comp i guess.
Old Nov 30, 2007 | 10:47 PM
Superado's Avatar
well, further research shows that the 7638-16 is a "Magnum" pushrod and the 7955-16 is a "Hi-Tech" pushrod
It appears that the Hi-Tech series has tapered ends and the Magnum series do not...
the 7955-16 are listed as genIII, which I knew...but the Magnum has no LSx listings...
Old Feb 17, 2008 | 01:26 AM
sharpshooter's Avatar
Did you go with the hi-tech's?
Old Feb 17, 2008 | 07:43 AM
Superado's Avatar
Thunder Racing equivalent...
Old Feb 17, 2008 | 11:00 PM
formulakid1's Avatar
The only difference between the two p/n's that you listed is that the Hi-Techs use a "cleaner" material and are a lil' stronger and stiffer than the Magnums.
Other than the markings....they "look" identical.
Old Feb 18, 2008 | 12:24 PM
Simon SS's Avatar
I think we need to run hi-tech. I have some magnum lifters and hi-tech pushrod.
low2001gmc
Jul 23, 2015 05:10 PM
bizle
Jul 22, 2015 07:31 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
