Comp 918's.. .610 lift??
Old Jan 14, 2007 | 11:41 PM
dirt track racer 81's Avatar
Default Comp 918's.. .610 lift??
ive read some posts on the 918s some say .600 lift and others say .625 lift
how would they handle a .610 lift?
Old Jan 14, 2007 | 11:52 PM
I'd check for coil bind,you are going to be close.They will probably be ok but a broken valve spring can be a real drag.
Old Jan 15, 2007 | 06:49 AM
Quik's Avatar
5 year bitches!
thats too much IMO
Old Jan 15, 2007 | 07:16 AM
tarinitup's Avatar
9 Second Truck Club
I thought they were maxed out at .600 lift. .610 is really pushing it.
Old Jan 15, 2007 | 07:24 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yup. 918's are good to .600
Old Jan 15, 2007 | 08:58 AM
bluecajun5.3's Avatar
11 Second Truck Club
you'll be fine up to 625 lift
Old Jan 15, 2007 | 09:37 AM
trever1t's Avatar
Beehive Shape Ovate Wire Springs
The 26915 and 26918 Valve Springs are specifically designed for the LS1 Chevrolet cylinder head and
can be used as stock replacements or in performance applications all the way up to 0.625” lift and at engine speeds to 7500 RPM. Engineered to fit stock heads with no machining, utilizing the stock valve seat and spring retainer. This valve spring can also be used in all applications with the specifications list-ed.
Installed Load: 105 lbs @ 1.800" 130 lbs @ 1.800"
Open Load: 293 lbs @ 1.200" 318 lbs @ 1.200"
Spring Rate: 313 lbs/in 313 lbs/in
Coil Bind Height: 1.085" 1.085"
Outside Diameter: 1.290"/1.060” 1.290"/1.060”
Inside Diameter: .885"/.656” .885"/.656”
Retainer: TI 772/Steel 774 TI 772/Steel 774
Part # 26915-16 26918-16
Description GM LS1 Spring High Load Spring
Maybe so!
Old Jan 15, 2007 | 05:50 PM
tarinitup's Avatar
9 Second Truck Club
Damn, that's news to me. I guess they pretty good spings huh.
Old Jan 15, 2007 | 05:57 PM
Derek @ EDO's Avatar
FormerVendor
just to be safe, personally i would go with a dual spring.
Old Jan 15, 2007 | 06:02 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
921 or the Patriot gold....forget about the 918's.
