Commercial Series LS Engine Assemblies
Old Apr 10, 2010 | 03:22 AM
Spoolin's Avatar
GFYS and STFU
Went from a 326ci to a 382ci motor is that right? Different heads, compression, rotating assembly, cam, possibly intake and don't know about the exhaust. Decent numbers I guess but not really breath-taking for a complete engine rebuild. Stock 5.3L puts down 295hp + 80hp so your looking at 375hp. Decent numbers.
Old Apr 10, 2010 | 06:56 AM
BigKID's Avatar
Originally Posted by Callies Performance
Hey Guys, I just wanted to give you all a heads up. Those of you looking for moderate horsepower and torque gains, we now have full rotating assemblies for truck applications. These kits fit the 5.3/6.2 and L92/LS3 Chevrolet! During testing this engine kit yielded a 79.75 horsepower and 73.74 torque gain! Let me know what you all think! Have a great weekend! -Adam @ Callies
I saw this series of components advertised in GMHTP recently. Curious, what makes these 'commercial' or any better for a low hp or stock rebuild? Are the LSc cranks of a lower grade material? Cost? The reason I am asking is I would like to rebuild a LS1 block I have with a 4" crank for my Tahoe. It's purpose is my DD and pulls the truck to the track so I am looking for an economical and reliable low-mid torque build not a high hp racer.
Old Apr 10, 2010 | 03:22 PM
fastnblu's Avatar
...Those of you looking for moderate horsepower and torque gains, we now have full rotating assemblies for truck applications. These kits fit the 5.3/6.2 and L92/LS3 Chevrolet! During testing this engine kit yielded a 79.75 horsepower and 73.74 torque gain! Let me know what you all think! ...
we took a 5.3, Added the Compstar LSc Crankshaft, I Beam Rod, a Mahle dish piston, and rings.
3.900 BORE
4.000 STROKE
6.125 ROD
12CC ON THE PISTON DISH
65CC HEAD
FINAL COMPRESSION WAS 9.92 TO 1
max hp was @ 5500 rpm
max tq was @ 4300 rpm
Adam, can u just show the actual before & after results w/ real #'s at given RPM rather than just say 80 this & 74 that? Info seems very vague, no pricing info.
ForcedTQ, what's the difference betw. 243 & 799 heads? What motor size do they come stock? 4.8/5.3 or 6L?
SO a 382 or 383 stroker is what we're lookin at basically? Like A Low Dime said, did the gains came thru the cubes, the ~1/2 pt. compression bump, or is it from the lighter rotating assembly?
Old Apr 10, 2010 | 03:35 PM
budhayes3's Avatar
PT's Slowest Truck
Tom, I was looking into the 243/799 heads today, and it seems that the 243's were originally LS6 heads (with sodium valves, etc.), and the 799's are what the GMT900 4.8/5.3's come with.
Old Apr 10, 2010 | 04:49 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
and the L33 and some Ls2 iirc
Old Apr 10, 2010 | 04:58 PM
budhayes3's Avatar
PT's Slowest Truck
That's right, I saw them listed too...I actually searched this section for "799". I'm still trying to find a list of all of the GENIII-IV casting numbers, with specs, pros/cons etc...
Old Apr 10, 2010 | 07:18 PM
ForcedTQ's Avatar
Thumbs up
Like the others above have said, they're the same casting (essentially, intake ports, exhaust ports, combustion chamber shape and size), just used on different engines from the factory. In some (02-06 Zo6 Corvette) instances, the exhaust valves in these heads were the Sodium Filled variety.
Old Apr 10, 2010 | 11:04 PM
trever1t's Avatar
enough of the banter, please keep your questions directed to our sponsor and the subject of this thread
Old Apr 11, 2010 | 11:19 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
So did the 5.3 that was dyno'd have the same cam in it then transferred to the stroker or was it added to the stroker build along with 243s that flow better than the stock 762s and a half a point of compression.
Old Apr 12, 2010 | 09:28 AM
Callies Performance's Avatar
FormerVendor
I will try and clarify quickly, It is has been Dubbed LSc, because we are targeting those who desire a little more torque, and a little more power. (basically guys with boats and campers, not racers) The Crankshaft is 5140 as apposed to 4340, and we recommend keeping this kit below 650 hp. If you are looking for more gains....you obviously know we have other products that will make that happen!. I posted figures, because I wanted you all to see the effectiveness of the kits, if you would like to see the dyno results, private message me and I can email or fax it to you.
