Can we make this a STICKY
Old Oct 5, 2007 | 06:59 AM
circusboy's Avatar
Default Can we make this a STICKY
I found this info on LS1TECH. We can make any adjustments need to make more truck oriented, then make a stick out of it
Intake
Free mods - 0-5rwhp
Lid - 5-10rwhp
Install
Big article on lids and dyno comparisions here
Filter - 0-5rwhp
MAF -
Very controversial as to any real gains, may even show negative numbers due to the fact it will be tricking the computer to run lean due to the larger diameter of the housing (good for stock, since you will gain a few hp by running a little leaner than the factory slightly rich setting; however, bad for modified vehicles). Stock MAF's are good to 500+hp. Once you are beyond that I suggest you contact your tuner (or local speed shop if you are doing your own) to find out what they recomend. Some will suggest taking the maf out and doing a speed density tune, which relies solely on the front O2 sensors.
Lid, MAF, Filter Install
LS6 (ZO6) Intake Manifold - 10-15rwhp
Install Graph
Holley Intake Manifold - 15-20rwhp
FAST 78mm Intake Manifold - 15-20rwhp
FAST 90mm Intake Manifold - 20-25rwhp
Sheet Metal Intake Manifold - 25+rwhp
Mainly for all out race engines or bigger CI engines.
Testing of Intake Manifolds Here
Also note that these hp figures can vary greatly due to cam size and head flow.
Ported Stock Throttle Body 5-10rwhp
Install
Cold Air Induction (CAI) - 5-10rwhp
Nitrous - Typically the size of the jetting will be the horsepower increase. Some company's rate it in flywheel and some to the rear wheels.
Exhaust
Listen
Cat-back - 10-15rwhp
Duals - 15-20rwhp
Catted y-pipe 5-10rwhp
ORY y-pipe 5-10rwhp
Shorty Headers 5-10rwhp
Mid-Length Headers 10-15rwhp
Long Tube Headers 15-20rwhp
Misc.
Underdrive Pulley 5-10rwhp
Tune 10-20rwhp
Electric Water Pump 5-15rwhp
Please DO NOT take the maximum number for everything and add it together and think you will gain this by adding these mods.
Muffler Flow Testing
All tests via an independent lab
All tests @ 15” wc
2 “ Straight Pipe 283 CFM
2 ¼ “ Straight Pipe 365 CFM
2 ½ “ Straight Pipe 521 CFM
2 ¼” Typical Bent tailpipe 268 CFM
2 ½” Typical Bent Tailpipe 417 CFM
2 ¼” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ¼” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ¼” Cherry Bomb 239 CFM
2 ½” Cherry Bomb 294 CFM
2 ½” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ½” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ½” Inlet/Outlet Gibson Superflow 267 CFM
2 ½” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ½” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ¼” Inlet/Outlet Thrush CVX 260 CFM
2 ½” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
2 ½” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ¼” Inlet/Outlet 138-152 CFM
Standard OEM 2 ½” Inlet/Outlet 161-197 CFM
This test was performed by 5.0 Mustang & Super Fords Magazine, December 2002 issue (page 55) on a '90 Mustang LX coupe with 370hp and 11 second potential. 66 pulls were made for this comparison:
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
Gadgetized
Aug 21, 2020 03:14 PM
Alco
Jan 9, 2016 10:27 PM
lxcoupe
Aug 24, 2015 08:16 PM
Martin4_8
Aug 13, 2015 07:31 PM
steves86ta
Jul 28, 2015 10:21 AM
