Can the crankshaft be saved?
Old Sep 25, 2009 | 04:18 AM
Default Can the crankshaft be saved?
A friend was doing an underdrive pulley swap on his truck and had the pulley bolt break off inside the crank, used an easy out to pull out the bolt but now has to rethread the inside of the crank. What size would it be? I've never heard of something like this, i thought it only happened with head studs
Old Sep 25, 2009 | 08:39 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I've seen it happen before (here) but don't recall the solution. bump TTT.
Old Sep 25, 2009 | 08:53 AM
charcold-bowtie's Avatar
Longer crankshaft pulley bolt, M16 x 2.0 pitch x 120mm long
Thats the specs of a long crankshaft bolt, used to make installing the balancer easier.
Old Sep 25, 2009 | 09:03 AM
Tootall's Avatar
heli-coil it . . . and get a crank pin kit, and hope that it holds
LARRY01Z28
28
Sep 28, 2015 07:54 AM
sTNT971
Sep 26, 2015 04:22 PM
MikeD.
Sep 18, 2015 09:55 AM
carid
Sep 10, 2015 09:07 AM
Forcefed81
Sep 8, 2015 10:02 PM
