Cam tips
Old Jul 30, 2017 | 12:39 PM
2006 Ava Z71's Avatar
Registered User
Default Cam tips
I have a 2006 Avalanche with a 5.3 with 706 heads. What is the best and biggest cam I can run and what other mods do I have to do to run said cam.
Old Jul 30, 2017 | 12:50 PM
terravast4's Avatar
if you are going big you will need valve springs, torque converter and a good tune
Old Jul 30, 2017 | 05:09 PM
03sierraslt's Avatar
What are your goals? What to you wish to accomplish with the cam swap?
Old Jul 31, 2017 | 12:53 PM
grey matter 04's Avatar
13 Second Truck Club
Bigger isn't alway better !
Old Aug 1, 2017 | 05:27 PM
Registered User
I would like to increase performance as much as I can without losing the drive ability of my truck.
Old Aug 1, 2017 | 05:47 PM
FFDP's Avatar
That still gives very little to work with.
What's your budget?
Do you want to run a stall?
Do you value the life of the stock weak 4L60e transmission?
If the answer is a smaller budget then go with a 212/218 cam, upgraded valve springs, a set of headers and a good tune. I'd upgrade injectors if the truck is a non flex fuel truck. The small 25hr/lb injectors are pushing it most of the time on cam swaps. Then pray the transmission holds for a long time and that the stock G80 rear diff keeps on keeping on.
Old Aug 2, 2017 | 07:04 PM
Registered User
My budget is pretty substantial, the transmission has been recently rebuilt but the truck has high miles the important thing to me is that the truck keeps the nice things I like about driving it I want all the gauges to still work properly I figured I would need a stall so changing the converter is not an issue I was already planning on changing the gears in the front and rear. Does the front and rear differential need to be changed and can you build the transmission or does that have to be changed too.
Chevyguy02
35
Nov 30, 2016 08:20 AM
CF7GO
Nov 14, 2016 03:04 PM
NorCalAnthony
Oct 21, 2016 11:01 AM
MAD_RACING
Mar 3, 2002 02:34 AM
