Cam And Rockers
Old Jan 12, 2008 | 04:00 AM
jkwalkercchs's Avatar
Question Cam And Rockers
i got a 5.3 03 avalanche im looking for a good torque cam
its lifted with 37s so im not wanting alot of top end i want the torque
whats the ratio on the stock rokers
summit has 1.8s for 350$ is it worth the upgrade
Old Jan 12, 2008 | 06:53 AM
sickREDsierra's Avatar
stock rockers are 1.7:1
some cams have a ramp rate too steep to successfully run 1.8's....which wouldnt really make any more torque on your motor to be worth...they would just raise the valve lift at .050"..... rou should call compcams with your setup and ask them what they think...
IMO you should look at the 212/218 low lift cam......but there may be better torque cams out there.
just do some reading. good luck
Old Jan 12, 2008 | 07:34 AM
grrrrrrrrr i hate reading
Old Jan 12, 2008 | 08:31 AM
00blackz71's Avatar
I had a 210/218 .551 lift 116 lsa in my 5.3 and I think it is a little too big if you are wanting torque. It really doesn't hit until about 2200-2400 rpms. I needed more torque lower than it gave me. Might be a good cam for a lighter vehicle but not a heavy 4x4.
Old Jan 12, 2008 | 10:53 AM
htsht's Avatar
Banned
What are you running for gearing? That will make more of a difference then a cam or rockers will.
Old Jan 12, 2008 | 05:16 PM
im goin with 5.13s
superchomper2003
Aug 26, 2015 09:39 AM
DrX
Aug 19, 2015 04:45 PM
Hmguyton
Aug 9, 2015 05:38 PM
BigEd_72455
Aug 8, 2015 07:37 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
