Cam opinions
Old Oct 27, 2007 | 09:46 PM
Stoichiometric's Avatar
Default Cam opinions
I have a 218 216 115lsa .527" .524" with 5 degrees of advance that I would like to put in a 4.8L 2wd RCSB. Truck has bolt ons but stock converter. I plan to change converters when the tranny gives up, don't know when that will happen. What do you guys think?
Old Oct 28, 2007 | 07:55 AM
zippy's Avatar
That is one strange cam.
Old Oct 28, 2007 | 05:24 PM
silver-mod-o's Avatar
Hunt&Fisherator
weird cam but it should work in there... if the LSA were tighter you'd be a little better off.
Old Oct 28, 2007 | 08:25 PM
With a tighter lsa would I make more torque lower in the RPM band? I like the wider lsa's lack of lope. The cam was originally spec'd for a turbo car, that's why it has the reverse split and wide lsa.
Old Oct 28, 2007 | 10:02 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Will help crutch the truck intake, it will have a broad power band, not quite so much power right out of the hole as say a 110lsa would, small lift is kind of odd too.
kush killer
Feb 17, 2016 09:20 PM
2500ZL1
Jan 25, 2016 06:30 AM
urdone
Aug 18, 2015 12:17 PM
lawhitediamante
Aug 12, 2015 12:14 PM
Aboss
Jul 9, 2015 10:28 AM
