Cam lobe overlap
I am looking at purchasing a cam with these specs: 208/217 .508/.509 114
I plan on using 1.8 ratio rockers, which will change the lift to .538/.539. I don't know how much the duration will change.
My concern is, how much overlap does this cam have, and how will it effect emmisions?
Originally Posted by doublenot
so would a 224/224 on 112 have no overlap?
http://compcams.com/Community/Articl...?ID=1726205736
Originally Posted by TurboGibbs
Here is a good article. I don't really care for the calculation above due to the many variables which it can't cover.
Oh and a 224/224 on a 112 sounds badass even with the stock exhaust
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
Originally Posted by RandomHero
You're right and that is a good article, but for stuff like this, it's not gonna make a huge difference. If he was building an all out drag truck I would use their method but for simplicity, the simple caluclation I got from XLR8NSS(I believe) will work just fine.
Oh and a 224/224 on a 112 sounds badass even with the stock exhaust![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
