cam kit options.
Old Jul 8, 2014 | 05:35 PM
2001sinistersilverado's Avatar
Default cam kit options.
Im looking to cam my truck. I have a 4.8 silverado. Im looking for a choppy sounding cam but i dont wanna have to replace my torque converter or anything like that. I dont really know that much about cams so any help or suggestions would be greatly appreciated. A friend suggested this cam but idk if it would work with a stock converter. http://m.summitracing.com/parts/cca-54-530-11
Old Jul 8, 2014 | 06:28 PM
Txblue's Avatar
Sdpc ht-1 cam. 214/218 duration 111 lsa. I have it in my 5.3 and it should chop a little more in your 4.8. I lost no low end and it pulls really good midrange and up top and I'm using my stock converter.
https://m.youtube.com/watch?v=ssnieM5PGm8
Open headers
https://m.youtube.com/watch?v=BJdY63R87tM
Flowmaster 50 series
Old Jul 8, 2014 | 07:23 PM
turboal1's Avatar
Default dyno
hey TxBlue, do you happen to have a dyno sheet on your truck ?
I would like to compare it with mine, I think Comp screwed me over
on the cam they sold me. I need a little more ammo to hit them with.
Old Jul 8, 2014 | 07:51 PM
Txblue's Avatar
No I don't have never been on a dyno. I did cam long tubes and mail order tune all at once and it was a completely different truck. And it's on a mild tune due to I still have a bone stock 290,000 mile 4l60e. The ht-1 cam from sdpc is a comp cam but sdpc specs. There is a speedo video on YouTube of me Rollin into the throttle up to 100 mph if that helps
https://m.youtube.com/watch?v=6cOV-IIJnpE
Old Jul 9, 2014 | 04:04 PM
jmgak47's Avatar
Here is a cam I spec'ed for a local guy with a 4.8L. It does really need a converter but he wanted one spec'ed for roll racing and for when he goes with a converter:
https://www.youtube.com/watch?v=5ytu...KaHY09a7Iy3JrQ
Old Jul 9, 2014 | 05:03 PM
Beau@SDPC's Avatar
Trucks Sponsor
The HT-1 is quite a popular 4.8/5.3 cam. Low duration and a tight LSA helps to make power early in the rpm range where it is really need in small cube, heavy vehicle applications. The 111 LSA gives it a super aggressive idle, yet the 214/218 duration allows the cam work well with stock converter applications. We keep them in stock for $374.99 and can put a cam kit together with PAC 1218 springs and pushrods for $614.98.
Old Jul 9, 2014 | 07:42 PM
Txblue's Avatar
Yeah I did a lot of searching before I pulled the trigger because it was my first cam swap and I wanted a choppy idle no loss of low end but pulls hard mid range and up top and I got everything I wanted. You said something about PAC springs... When I ordered the kit y'all said ls6 spring are fine and that what I went with. Should I change? Been running this setup about 25,000 miles no problem
Old Jul 9, 2014 | 08:32 PM
jmgak47's Avatar
Your right on the limit, since you have that much mileage on them I would replace them with a better spring.
Old Jul 9, 2014 | 08:57 PM
Txblue's Avatar
What you you recommend? I don't want to go overkill and cause more stress on the valve train.
Old Jul 9, 2014 | 09:44 PM
jmgak47's Avatar
The PAC 1218's like was recommended by SDPC
