cam i use any ls1 piston/rod/ring set-up in a 5.3L ?
Old Aug 29, 2006 | 11:39 PM
Default cam i use any ls1 piston/rod/ring set-up in a 5.3L ?
as the title states- can i use these pistons in a 5.3L???????-
http://www.sdpc2000.com/catalog/4428...sh-Pistons.htm
also weakest part 5.3L- trying for 700 to 750whp- just do pistons/rods/rings? and some ARP rod bolts?
Old Aug 29, 2006 | 11:48 PM
onebadrubi's Avatar
You are going to have to bore the motor. That is about all I know or can help you.
On a personal opinion I really dont particulary like JE pistons. Havnt really herd any good/bad things or anyone using them on these type of motor builds.
Old Aug 30, 2006 | 04:50 AM
TURBHOE's Avatar
if you bore the motor to the correct ls1 piston size then yes all else will fit.
lawhitediamante
Aug 12, 2015 12:14 PM
Denali08
Aug 9, 2015 04:34 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Black-Syde
Jul 6, 2015 02:12 PM
